- 67 Cutlass from bench to buckets
- Bucket seat mount vs bencg seat mount
- 65 heater core leaking
- 1964 Oldsmobile 98 Speaker system question
- Looking for 1971 442 inner rear window sweeps/felts
- Headliner Material - Where to buy?
- Remote Mirror Escutcheon
- Silver trim
- Bench seat disassembly cutlass 4 door
- 1970 Cutlass Supreme Bench Seat Spring Location
- Center console fasteners
- Dashboard help!
- 1979 Cutlass Interior Dye Color
- Door Panel Backing Plate "Clips" for 1970 442
- Door Panel Trim - Silver Strip re-do
- Seat upholstery for Toronado Trofeo/Touring Sedan
- Correct Dark Green Metallic Vinyl Dye for 1970 442 Coupe
- Prep for Plastic Parts like Kick Panels
- Seat Buttons
- dash removal
- Legendary Interiors product wait time update
- Headrest covers
- Re installing dashboard
- Window Regulator Parts
- Quarter panel window trim attachment
- Power Bench Seat
- Door panel trim
- Interior plastic
- 1970 Oldsmobile 98 Interior on the "cheap"
- 1962 Starfire Steering Wheel Color
- Console box
- Center Console - Oldsmobile 442 1971 Automatic
- Seatbelts
- Bench seat upholstery
- ANybody using Legendary bolstered buckets?
- Dash Removal - 1978 Delta 88
- Acme Headliner Board FAIL '78-88 Cutlass
- Advice on glue needed- vinyl to hard plastic
- 55 Olds Super 88 4 door fresh air vents
- Headliner
- 1970 4 speed shifter boot
- 1970 442 Bucket Seat Foam
- Rear Seat Panel for 67 Cutlass
- 1969 442 bucket seat nuts?
- Can 4 Door Bench Seat Be Made to Tilt Forward For 2 Door
- Headliner available?
- Door Panel Question
- 70 cutlass interior questions
- ‘78 Toro Door Panel Material
- Sail panel
- Faded interior trim by windows 84 98
- Seat piping installation
- Window Squawking
- Trimming Auto Console for 4 Speed
- 1969 442 green N34 wheel swap
- '71 Supreme Door Panel Carpet
- Are rear seat belts supposed to retract automatically?
- 62 F85 Front Seat
- Trim chrome - broken tabs
- Console assembly and ID of parts
- Interior Makeover
- OPGI interior
- 66/67 Cutlass
- Outer window felts
- OER Dark Carmine Red Interior Paint — 1978 Holiday 88
- Incorrect listing pockets?
- Camel Tan Headliner Need
- Power seat extenders availability 🤔
- Experience with removing carpet
- Power vs manual bucket seat
- Front Seat Belt Removal - 1978 Bucket Seats
- New Rear Convert. Seat Foam
- Is there a vinyl repair tape?
- Help with seatbelts
- 1969 98 seat compatibility
- 1969 gold convertible top
- 1970-72 dash pad installation nuts
- 59 98 4dr sill plates
- 1970 Oldsmobile 442 Gold headliner supplier?
- Watershields
- 1965 cutlass convertible Repop (opgi) window felt kits
- 1966 442 Interior Lighting
- Sun Visor Vanity Mirror
- 75 Cutlass Tilt / Non Tilt Steering Column Ignition Key Lock Cylinders Diff?
- Convertible top 1967 CS 442
- Interior fabric comparison
- Rear window roller replacement?
- legendary sales
- New 68 Rear Seat Upholstery…
- 1977 Delta 88 2 Door — Door Handle Pull Covers?!?!
- Reproduction pieces
- Bucket Seats
- 69 Radio Questions
- Firethorn Red Velour Upholstery Fabric Supplier???
- 1966 Cutlass Interior
- roof pad
- 1964 oldsmobile 98 factory floor mats
- How good or great is the Legendary Auto Interior Discount?
- Shoulder belt pin plastic washer
- 77-84 98 2 door vs 4 door window part availability
- Interior fabric suppliers
- 65 F85 Column Shifter Lever
- 66 olds front bench seat adjustment
- '76 Cutlass Dash pulling away from backing
- Will a 69 Chevelle bench seat fit a 67 2dr Cutlass?
- Converting to power windows '77 Cutlass
- Convertible Top Installers
- 1962 Starfire Interior
- Column Shift Lever
- Is 68-69 442 perforated seat material available?
- Stop belt buckles from denting your console
- ‘72 98 water stains on ‘cloth’ seats
- Convertible Top
- 1966 deluxe holiday coup square upholstery buttons
- Best place to purchase replacement trim..
- Assembled vs Unassembled
- 68 Delmont front seat
- OPGI interior kits
- 1964 to 1966 Starfire Shifter Diagrams
- DIY Backseat Bench Seatbelts
- 1969 Cutlass dash hardware location
- Question on where’s the exact location for the center console brackets.
- Complete Upholstery Kit
- Rear arm rest
- Which style AC compressor is best?
- 68 cutlass supreme seatbelt restoration
- Interior paint
- 1966 Olds 98 wood grain vinyl that matches the dash wood grain
- 1966 98 Door Panel Stainless: more than you ever wanted to know
- Old School Seat belt retractors
- My next quest...
- Deluxe seat belts or standard 🤔?
- Squeaking dashboard
- Courtesy vs. Arm Rest lights
- '72 cutlass auto shift console install - cable hole specifics?
- Twilight Sentinel Headlight Switch Mounting in a '75 98
- Power Window Switch Locations?
- Quarter Window Rollers
- What are 67 Cutlass rear seat measurements?
- '72 98 two door - rear seat back rest removal
- Speedometer faceplate id
- Converting Console from Automatic to Manual
- Inner door 1967 delta 88
- Inside door jam interior trim
- Glove Box Large round knob lock removal & Decal
- Back windshield/vinyl
- Bench Seat Cover
- '69 442 convertible boot retention
- 1971 VistaCruiser front armrest pads - same as '71 Cutlass?
- Door panel removal on ‘72
- Headrests for 67 442 bucket seats
- Paint for black 68 Cutlass dash
- '69 Cutlass/442 doorjamb windlace
- Rear Seatbelt Length
- Seatbelt Mount Sealing Material
- Convertible Top Frame Alignment
- 68 Cutlass ignition switch and light switch threaded benzel cup removal
- Butyl tape/rope for splash shields
- Door Glass Vendor - '72 442 Convertible
- Stuck Seat belts!
- Window sweep kit
- Flooring & Sound Dampening Material
- Dashpad Bead Moulding
- 70 hard top rear arm rest base
- 68 Cutlass assembly manual door pics needed
- door armrest for 1966 98 hardtop sedan
- Hurst Dual Gate Shifter rebuild
- Seat piping bullets?
- 63 door panels
- Help with 1966 dash removal
- Dash Face Chrome Trim
- Rpui
- Rear Convertible Armrests Backing Material?
- Floor liner or sound deadner?
- Dashboard Push Clip
- Stripping seats and floor to weld in new pans 74’ Delta 88
- 1970 cutlass steering wheel Sport delux?
- Bucket seat brackets
- Rebuilding bucket seats
- 1978-88 Cutlass Dash Pad, request for reproductions
- Rear view mirror replacement
- Would like advice on installing ABS Dash cover for 78 Cutlass
- 1969 Vista Cruiser Steering Wheel - Need Help with ID and Horn
- Looking to increase bench seat adjustment range / putting it further back
- HVAC system not working
- Correct Screws for rear of seat ash tray? 74 Salon
- Armrest pad removal 🤔
- Value of used front power seat screw actuator - 65 Olds 98
- steering wheel
- Seat belt webbing
- bench seat belt
- 1969 442 trunk molding
- Need help with 65 cutlass steering wheel
- 66 interior questions
- Modified rear seats
- 72 Dash bezel
- Powder Coating Convertible Top Mechanism?
- Sail Panel Clips
- Listing Wire on Seat Foam
- Rallye 350 dash
- Rear View Mirror Mounting/Headliner
- 69 Cutlass S convertible header bow
- Cleaning the 'cloth' inserts in my '72 98
- Windshield Clips
- package tray ?
- 1972 Cutlass Console
- '72 98 - clock and dash bulbs removal?
- rear view mirror
- Legandary Vs PUI
- Hoping to get some parts id
- Pictures for Interior Inspiration
- 67 Bucket Seat covers ID
- 69 Cutlass trim stick tack strip
- Package tray
- Ignition key operation
- Interior paint
- ID 1966-70 pedal firewall plastic
- ID 67 seat belts bench or bucket codes
- Supreme vs rally seats
- Best interior trim product for lasting shine
- Has anyone done their Olds 442 in real leather?
- Speedometer face
- 65 cutlass rear seat upholstery
- Vinyl Seat Protection
- 1968 Cutlass Holiday S vs 1968 cutlass sport coupe
- Console Shifter
- New Upholstery - Driver's Seat '67 Cutlass Supreme
- seat color
- Questions about seat belts & interchange
- Paint for metal dash in 71
- Convertible Header Bow Fit
- vista cruiser seat covers
- Courtesy lamp harness help
- Looking for 1972 Cutlass Supreme Headliner Experience
- Headlight switch bezel | blue illumination film ?
- 70 Sport Coupe B Pillar Mouldings
- Dry Dash pad
- swivel bucket seats
- 1970 442 Manual Shift Boot Ornament
- Legendary interior vendor
- Glove Box Liner
- 69 Cutlass window felt install
- 1969 442 Holiday Coupe Package Tray
- Bench vs Bucket Seat Belts
- 1968 Cutlass Manual Console Overlays
- Set belt set help please
- regarding 1972 olds cutlass supreme dash replacement
- Repro Kick Panel Supplier Differences
- 35 Oldsmobile interior
- dash pad
