PDA
View Full Version : Interior/Upholstery
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16
  1. 1972 delta 88 2 door interior mods
  2. sealing roof weatherstrip
  3. 67 442 dash Pad installation
  4. 71 cutlass Convertible Rear seat cover wanted
  5. 72 442 convertible passenger vanity mirror glue
  6. 67 Cutlass front bucket seats
  7. 72 Cutlass S Saddle Brown Seat Interior Dye?
  8. 72 cutlass front bench installation issue
  9. Replace evaporator or buy new??
  10. Dash pad respray in place
  11. 68-9 Cutlass Dash pad question
  12. 68 442 Seat Belt question
  13. Coupe to convertible seat modification
  14. 1966 Cutlass convertible door panel install.
  15. How To Clean Pearl White Interior?
  16. Correct Brake Pedal Pad for Disc Brake Equipped Cars
  17. 67 Cutlass 2 door back seat install
  18. Power window swtich location
  19. 72 cutlass a.c selector
  20. Chrome Seat Trim Endcaps
  21. Convertible boot rail - orientation
  22. Sport Steering Wheel Horn Button ID/Question
  23. 69 Dash Plastic Restoration
  24. Rear view mirror resto
  25. Has anyone dyed headrests white?
  26. Tic-Toc-Tach in Cutlass dash help!!
  27. Glove Box
  28. Console Removal 1970 442 TH400 Stock Shifter
  29. door panel options
  30. Sticky door latch?
  31. 1972 Steering Wheel Insert / Anyone Repro This??
  32. A.C ducts
  33. Calling all wood experts
  34. Black Plastic Footwell Panel ??
  35. 4-door a-body sill plates
  36. 1960 Oldsmobile rear sunvisor
  37. Ames Perf window cranks
  38. How-To: custom fiberglass pillar gauge pods
  39. Oldsmobile Hanger Hooks??
  40. door window comes only partially down
  41. Legendary 1965 Sport Coupe Set Covers?
  42. Screws/bolts for interior peices
  43. 72 cutlass seat belts
  44. 72 cutlass glove box
  45. 66 heater knob removal
  46. What's the best chrome paint for dash trim.
  47. brown copper houndstooth upholstery fabric
  48. Door inner panel water deflector 66 Cutlass Vert.
  49. Interior redo on my 72 cutlass part 1
  50. 1970 CS Bench Seat Adjustment
  51. Seat belt tag information.
  52. Dash VIN trim 71 Cutlass
  53. Center AC vents Chrome or black?
  54. Dyeing parchment interior pieces
  55. 72 Cutlass S bench ripped, seat cover ideas?
  56. Non-A/C 1972 Cutlass Center Vent
  57. '76 Salon's Console Door Fell Out of Its Track!
  58. Metal Panel Between Package Tray & Rear Window?
  59. 70 Olds Glovebox Door Support Arm?
  60. All Thumbs Upholstery Inc. - carpet and sound deadener
  61. All Thumbs Upholstery Inc.
  62. “CS” door panel emblems
  63. Looking for ideas to renew console interior
  64. 1966 Cutlass 4-speed console carpet.
  65. Rear Interior Quarter Assembly Question 1968 Convertible
  66. Turquoise basketweave headliner
  67. in stall wood applique' 1969 442
  68. 1970 442 Gauge Removal
  69. Wood Applique Prep & Install ?
  70. Headrest for 1972
  71. 1972 Cutlass seat cover button locations
  72. 71 Bucket Seat Headrest ?
  73. Seatbelt retractor cover fitment
  74. PUI preassembled door panels (window crank knockouts).
  75. 72 Cutlass LED Dash Light Replacement?
  76. Seat bolt nuts
  77. 72 cutlass high beam switch placement
  78. 1975 cutlass package tray??
  79. new door panels -preassembled or not?
  80. 76 toro dash pad cover
  81. Bench Seat Track Carpet Guard?
  82. Sport steering wheel horn button color?
  83. 67 CS Town Sedan arm rest bases
  84. 1961 steering wheel redo
  85. Interior paint or not.
  86. Under dash heat/ac parts?
  87. how would you fix this
  88. Carpet Install '70 Cutlass
  89. Reproduction seat belts
  90. 72 Cutlass door panels
  91. 70 Sport Mirror install ?
  92. How to Convert 69-72 Buckets to 68's
  93. rear seat corner panels for 1975 delta 88 convertible & 2 front power bucket seats
  94. '70 Cutlass Shift Lever End Assembly?
  95. Headliner installation 442 1970
  96. Rear seat?
  97. Experts Advice Needed AC Vents (Chrome/Silver trim)
  98. Sun Visor Vanity Mirror - Orientation
  99. 1971 442 Center A/C vent.
  100. Legendary Sale Until 2/14
  101. Floor pans surface rust and paint
  102. Pillar paint?????????
  103. 70 Black Dash Pad (Type Of Paint?)
  104. Cigarette Lighter issues
  105. ‘72 Cutlass pull strap removal
  106. Sport Bench seat re-upholstery
  107. 1967 CS Holiday Coupe Dash Removal
  108. Metro Soft Seal rubber problem
  109. Seat Buttons
  110. Singing the BLUES
  111. Need Help on Interior restoration for 60s oldsmobile super 88 holiday sedan
  112. Correct Sheen For Underdash?
  113. Another Seat Foam Question
  114. Seat Upholstery color?
  115. 66 Cutlass Steering Wheel
  116. New Carpet Needed- Have Question Though
  117. Dash Pad
  118. 67 C/S Bucket seats refurb
  119. Various '70 Interior Questions
  120. Remove Seat Belts through Front '70 Front Bench Seat?
  121. 66 Cutlass Radio Plate
  122. '68 Cutlass rear seat backrest mounting bolts
  123. Anyone have an original '66 '67 Strato headrest?
  124. 69 Cutlass aftermarket seat help!
  125. 1972 delta 88 manual to power window conversion
  126. Kick Panels Cutlass 1966
  127. ' w-31 console install
  128. Seat Adjustment Control Knobs
  129. Will a '70? Toro Pwr seat base work for '70 Cutlass ?
  130. A new guy with a 68 Cutlass Convertable
  131. 69 Cutlass S Coupe interior help needed
  132. 1965 442 Fawn convertible top
  133. '70 Cutlass/442 Speedminder Speedo needle question
  134. 72 Cutlass glove box diagram & fasteners
  135. Speedometer Rebuilds?
  136. 1968 Package Tray
  137. 71 Convertible Interior colour change
  138. Cutlass seats
  139. 67C/S headliner
  140. Drivers side bucket seat
  141. Bucket Seat Fold over Steel band
  142. Bucket seats over carpet
  143. Radio delete/cover plate
  144. 70 - 72 convertible door panel question
  145. Shifter lever connection
  146. Clock Lens removal
  147. 1953 Oldsmobile "Trim No. 77"
  148. 67 cutlass rear seats
  149. Firewall heater box insulation?
  150. 69 olds 98 rear window regulator
  151. 74 Cutlass Supreme Buckets
  152. 1968 Cutlass Auto Console Shift Knob
  153. Steering wheel trim color
  154. Carpet wear plates
  155. bucket seat spring replace
  156. '68 442 Front Seat Belt Retractors - Side?
  157. Door lock cylinder
  158. Door Panel Trim
  159. 72 A Body Courtesy Lights “90”
  160. Help needed on 69 Cutlass interior colors
  161. 73 Cutlass S trunk mat
  162. 67 Cutlass 442 rear seat back bolts
  163. 1968 Courtesy Light Question
  164. 1975 Delta 88 Convertible - Ash Tray
  165. A/C vents
  166. 83 Factory Stereo's Options?
  167. dash cap census
  168. Distinctive interiors
  169. 1978 base Delta 88 interior cloth
  170. 3 or 4 point harnesses in a 65 cutlass conv.
  171. seat belt decal
  172. 1950 olds 88 interior question
  173. 65 Cutlass power bucket seat
  174. My bucket seat and console conversion
  175. 71 Flat Top wagon trim code 929 Sienna ??
  176. Finish of seat rebuild
  177. White Interior Question
  178. Rear seat compatibility
  179. 1968 convertible top boot cover install issue
  180. FOUND ON E-BAY- NOS seat material!
  181. Best carpet for 1973 Supreme????
  182. Help Finding Fastener for Instrument Panel to Dash
  183. 71 Cruiser Upholstery source wanted
  184. Tale from a first time door panel installer
  185. Electric seat motor???
  186. 68 442 glove box install question
  187. Glove box lock for 66 Dynamic 88
  188. Interior panel issue
  189. Headliner for 1980-85 Delta 88
  190. 1957 Super 88 dash modifications
  191. Bucket seats column shift?
  192. Fixing The "Sticky Steering Wheel" Syndrome
  193. Adding gauges - need advice on routing
  194. Seat belt upgrade
  195. Convertible Top Ram Supplier
  196. '72 Cutlass Glovebox Light - Need pics!
  197. 65 Starfire/JS1 Console Inserts?
  198. Convertible top repair
  199. Rubber floor mats
  200. 1973 Swivel Bucket Seats
  201. AC system questions 70-442
  202. replacing bench seat w/buckets
  203. Please help...looking for an ashtray
  204. rear seat frame 64 F-85 Club Coupe
  205. Which parchment paint to use 69 442?
  206. Door panel repair tips, tricks, voodoo?
  207. Driver Side Mirror Contol - How to remove?
  208. Rearview mirror install
  209. Recommendations for interior chrome trim and armrest re-paint?
  210. Stereo & Speaker Options - 1972?
  211. 72 console door lock/latch?
  212. How to change Vent Window weather stripping on 68 cutlass
  213. 71 Cutlass Interior Panel Removal
  214. '72 Supreme seats
  215. Tr 979
  216. Steering Wheel Chrome/Woodgrain strip Repair
  217. Arm Rest Backing Plates
  218. Bench Seat Arm Rest Installation
  219. Interior restoration paint
  220. Vista Cruiser interior GM A-Body F-85
  221. glove box lock/latch tool
  222. 1977 Cutlass Supreme Brougham
  223. New Seats/too high
  224. 1960 oldsmobile 98 star-lite headliner
  225. Is it fixable?
  226. 1967 A body interior parts interchange
  227. 72 Cutlass non-floor shifter console conversion complete!
  228. 62 Dynamic Dash Pad
  229. 72 Cutlass console resto - white?
  230. Convertible top boot rail-need pics!
  231. This do-hicky-thinga-majig?
  232. 1970 Cutlass/442 Dash Vent
  233. 70-72 Cutlass console - custom solid top plate?
  234. 1960 oldsmobile 98 dash pad
  235. 1969 442 heater control paint
  236. 1950 Olds air vent chrome brackets
  237. 62 Dynamic Convert latch
  238. Cant find upholstery
  239. Oldsmobile 1968 - gold leatherette
  240. Aligning Windows 71 Supreme Conv.
  241. Interior Door Handle Mechanism
  242. PUI Window Felts
  243. dome light assemblies
  244. 1969 Cutlass Buckets
  245. Cutlass Interior Vendor Selection
  246. Seat Covers for 1963 Super 88
  247. 67 Glove Box Lock
  248. 1971 Cutlass Console Help!
  249. Needing help with sport steering wheel install
  250. Door Window Issues
