Rubber floor mats
Old Jul 12, 2017 | 05:56 AM
Lsx442's Avatar
Rubber floor mats
I just picked up some rubber floor mats for my 69 442 but I have a question. I noticed that they have a thin circle where the bright light switch is. Is the mat supposed to lay over the switch or should the hole be cut out so the switch goes through the mat?
I had carpeted mats in my 77 442 and they had a grommet to fit around the switch
Old Jul 12, 2017 | 05:58 AM
The mat goes around the brights switch. Meaning the circle needs to be cut out if it isn't already.
Old Jul 12, 2017 | 09:41 AM
The repro mats need the headlight dimmer switch hole to be cut out. You can use an exact knife or a proper size hole saw on your drill. This is the same thing with the repro trunk mats. They need the oval cut out for the Jack tie down
Old Jul 12, 2017 | 12:12 PM
Lsx442's Avatar
Thanks to the both of you. I felt like it needed to be cut
Old Jul 12, 2017 | 01:49 PM
What mats did you get?
Old Jul 12, 2017 | 02:45 PM
Lsx442's Avatar
Repo black rubber mats with Oldsmobile embossed on them. Wish I could have found an set of red mats to match my interior.
Old Jul 12, 2017 | 02:51 PM
Which vendor did you purchase from and are they heavy?
Old Jul 12, 2017 | 05:05 PM
Lsx442's Avatar
Year One. I only went with them because I had a discount. I originally was going to purchase from The Parts Place since they were cheaper but my discount made them the same price
They are decent weight but lighter than I expected. Overall I'm satisfied with them
Old Jul 12, 2017 | 06:59 PM
They're pretty much all the same product sold by different vendors.
Old Jul 12, 2017 | 07:36 PM
I've never seen a set up close, which is why I asked. My current mats that were pulled out of a used truck trade at work are starting to come apart.
Old Jul 14, 2017 | 11:17 AM
Eric,
They are the same consistency and design as OEM. Only available in black as repros though. That would work well in your car. IMO they do smell a bit until they get aired out.
Old Jul 14, 2017 | 11:27 AM
I like the old rubber ones with the racing flags crossed in a shield. Aftermarket period correct ones.
Olds442redberet
Feb 20, 2014 06:37 PM
misercola
Dec 2, 2013 09:45 AM
at3reg98
Jun 23, 2012 08:23 PM
misercola
Jan 25, 2011 06:03 AM
Delmont 88 425
Dec 2, 2010 01:24 PM
