70-72 Cutlass console - custom solid top plate?
Old May 12, 2017 | 08:07 PM
70sgeek's Avatar
'72 Cutlass ragtop
has anyone here seen a 70-72 Cutlass automatic console where the top plate was replaced with a custom solid top that didn't have the shifter opening?
I just installed factory buckets in my column shift ragtop and think it would cool to install a factory console with a solid top plate - I assume something could be machined maybe out of thin metal plate and covered in woodgrain overlay?
Not looking to convert to full-on floor shift anytime soon but would avoid making any permanent mods to the console that would prevent me from doing so later if ambition and $$ permitted
Old May 13, 2017 | 01:09 PM
Not in those years, but Olds actually did this from the factory on one very obscure option combo. In 1967, you could get the column shifted three speed manual in the Delta Custom that came with bucket seats. Olds used the 67-69 style AT console, but the die cast plate where the shifter normally goes was blanked off. You could probably count the number of cars built this way on one hand. This is shown in the full size car PIM for 1967.
Old May 13, 2017 | 05:18 PM
70sgeek's Avatar
'72 Cutlass ragtop
I may have found a reproduction source whom does a lot of Cutlass console resto work - they say they actually have a reproduced solid top plate available along with the proper wood grain overlays for 70-72.
waiting on more info.
Old May 14, 2017 | 07:06 AM
allyolds68's Avatar
I would assume you're probably talking to H&H
If not contact Jeff because I'm sure he'll make you whatever you want
http://www.hhclassicauto.com/mission.html
Old May 14, 2017 | 11:44 AM
VC455's Avatar
Barely Registered
I may have found a reproduction source [who can make a] solid top plate available along with the proper wood grain overlays for 70-72...
Please post your contact. I have been searching for a long time for that. I have a T-56 transmission where the stick is farther back than the Muncie stick was. I contacted H&H 15 years ago who told me I would have to buy the stick top plate and the automatic top plate to cover the areas ahead of and behind the stick location.
What's wrong with this picture? They make the solid plate and then cut it to suit either of the stick or auto options. But they can't sell an uncut plate? I considered that greedy and a disservice to the car community. You can guess what my answer was.
Old May 19, 2017 | 07:02 PM
70sgeek's Avatar
'72 Cutlass ragtop
H&H is the source I am ultimately going with, as they can make the bezel and fit it with the correct woodgrain overlay. It's being made for me at this writing so I'll post photos of it when received
6884rocket
Feb 13, 2014 03:43 PM
BeenThere
Aug 5, 2013 08:21 AM
z28summit
May 17, 2013 07:20 PM
6884rocket
Apr 25, 2013 05:26 PM
