62 Dynamic Dash Pad
62 Dynamic Dash Pad
I have a 62 dynamic 88 that has a dashpad on top of the dashboard.
My question is this: If I remove the dashpad, can I access the switches or clock from the top of the dash or will I need to remove the entire dash to replace a few items in the dashboard?
Any help is appreciated, Thanks
No. I just took mine out of a 1962 Dynamic 88 two door no a/c first I loosen the radio front nuts they are behind the adjusters I took out the glove box liner it helped you can get the radio support bracket take it out pull out the front speaker connection ,antenna lead,and the green wire with the radio loose you can pull the speaker connection out. Also if yo have switch above the radio take the two screws out disconnect the white wire slide out the radio how you can get the three screws it's a 1/4 socket , the radio is two screws 3/8 socket . There are two wires power wire and light wire hope this helps .
