74 Cutlass Supreme Buckets
Old Oct 19, 2017 | 04:34 PM
sammieolds's Avatar
Hi I’m looking to get a set of buckets Black is there a list or a knowledgeable web site for that
I’m sure a lot of a body’s would fit
Any help Appreciated
Steve
Old Oct 19, 2017 | 04:40 PM
Paladin31's Avatar
I have a few sets, they aren't specifically from a 74, but all standard buckets fit 73-77 GM A bodies that had standard buckets already, if your car had & are replacing swivel for swivel buckets its a even swap. However the mounting locations are slightly different for swivel than standard buckets and the seat belts are totally different.
Brett
Old Oct 19, 2017 | 05:28 PM
sammieolds's Avatar
I have a split bench
New upholstery
New upholstery
Old Oct 19, 2017 | 06:36 PM
Paladin31's Avatar
#1 NICE car, I like that color. The bench seat uses same outboard mounts as a standard bucket, you would need to add the inner mounts & then get seats. Also need the long seat belts & stalks for the inner female sockets, good luck on OEM they shatter like glass when old. I have heard that you can modify stalks manufactured for modern cars, just don't have the web addresses to share. Hope this helps
Brett
Brett
Old Oct 19, 2017 | 06:38 PM
texxas's Avatar
1973-77 Strato bucket seats use the same out board mounting points as the bench seat mounts and use the same seat belts as the bench(rear leg mounts on retractor housing), just delete the middle set of belts. I do not know if the inboard mounts for your 60/40 seats can be used for buckets. And as long as you're swapping to buckets MAW get a console and floor shift too.
Old Oct 20, 2017 | 03:59 AM
sammieolds's Avatar
Thanks Guys you’re right Brett the coat hooks came off in my hand I tryed to hang a small wireless speaker on it
Old Oct 20, 2017 | 05:12 PM
Paladin31's Avatar
Seats & sundries
Since Texxas mentioned it....I have a couple pieces here and there let me know if I can help
Brett
Old Oct 21, 2017 | 02:40 PM
sammieolds's Avatar
A couple lol when I do this I plan on building a small console and putting a radio in it keep the shift up top
I’ll keep this in mind if I change my mine
Steve
Old Oct 21, 2017 | 04:44 PM
Paladin31's Avatar
if your still using bucket seats then, perhaps a 73-77 console cut off at the coin tray area (sits just fore of the shifter slots) Thus it would still fit the floorpan contour, be easy to anchor, and you might use the 'garage door' compartment to secure the radio.
Just something to think aboiut
All the best,
Brett
Old Oct 21, 2017 | 05:17 PM
76olds's Avatar
Hookers under Hood
Hey Steve,
Just some ideas to pass along to you here.
A member on the new 73-77 oldsmobile forum took a 73-77 console cut it down to fit between his 60-40 bench.
It looks very nice, did a really good job!
Another member pulled his bench out, put a nice set of recovered buckets and console in, put some cup holders in place of the shifter.
It also looks really nice.
You should check it out.
Brett is our 73-77 parts, go to guy on here and the other Olds forum. He usually stocks a couple parts for us haha.
Most of our wives would kill us LOL, so we let Brett keep all the extra 73-77 parts stock at his house haha.
Your car look amazing Steve, nice interior!! Cut a console down it will look amazing!!
Cheers
Eric
Old Oct 22, 2017 | 03:14 AM
sammieolds's Avatar
Good info guys
Old Oct 24, 2017 | 05:21 AM
Platinum Al's Avatar
I am the guy Eric mentioned. Here's mine with bench seats and then I put buckets in. My cut console is for sale.
Old Oct 24, 2017 | 05:24 AM
Trans am buckets recovered in NOS material to match my rear seats.
Old Oct 24, 2017 | 09:23 AM
DrOldsMN's Avatar
Al where did you find NOS material? I want to do the same with my 76 Brougham black interior.
Old Oct 24, 2017 | 10:31 AM
I bought it off of EBay. Company is Automotive Restoration Supply. Phone is 613 925-5863. Helga Keller is the owner. Hope she has want you need.
Old Oct 24, 2017 | 11:27 AM
DrOldsMN's Avatar
Thanks, I'll give them a call.
Bosshoff
May 20, 2016 07:00 AM
Prophe'c
Oct 20, 2014 03:38 PM
oldspackrat
Oct 24, 2013 06:50 AM
deflepnut2003
Sep 9, 2012 03:11 PM
geowindow6768
Aug 1, 2008 08:03 PM
