1966 Cutlass convertible door panel install.
Old Jun 2, 2018 | 06:09 AM
35tac's Avatar
I plan on opening up the door panels on my 66 Cutlass vert to lubricate required areas, install a new water shield and install new window crank handles. I have searched the forum, CSM and Fisher body manual and have not found an illustration that shows the installation of the circular tapered springs and plastic bushings behind the window crank. I need some help to install correctly. Also searched you-tube but found nothing specific to my car.
Wayne
Old Jun 2, 2018 | 07:02 AM
RandyS's Avatar
If memory serves, the spring goes between the door and the panel, with the plastic 'washer' goes between the panel and the crank. I had to leave the springs off of my car because of the splines in the crank not being deep enough.
Old Jun 2, 2018 | 09:41 AM
35tac's Avatar
So that said, the taper of the spring goes toward the window crank and the large end is at the back of the door panel. That sound logical. Unless any one has more, thanks for the help.
Wayne
Old Jun 2, 2018 | 10:27 AM
RandyS's Avatar
Wayne
Just the opposite, the small end toward the door, big end toward the panel.
Old Jun 2, 2018 | 04:53 PM
oldolds88's Avatar
it needs to push the panel out not the handle. the spring should not come thru the panel unless the hole has been enlarged. my 65 has them too
Old Jun 2, 2018 | 08:30 PM
35tac's Avatar
Thanks very much to all for the help.
Wayne
budg
Mar 22, 2018 08:51 AM
SnakeBit
Jul 3, 2016 08:47 PM
W-27
Dec 26, 2013 06:03 AM
wcourt3010
Dec 6, 2011 12:06 PM
AHazzardToAll
Jul 7, 2008 12:06 PM
