67 cutlass rear seats
Old Nov 4, 2017 | 12:12 PM
brianbeez67's Avatar
Hey guys, rebuilding rear seats for my 67 C/S. Has anyone tried to re-use the wiring that was embedded into the burlap for the seat bottom? The term listing wire- does it require a certain thickness wire ? thanks Brian
Old Nov 4, 2017 | 02:26 PM
RandyS's Avatar
Suggest you reach out to member 'Rambow', he is the seat Guru.
Old Nov 5, 2017 | 06:03 AM
Roger60's Avatar
I have reused the wire if it is in good shape. My 67 conv. rear seats had been remade at some point, and they sewed some piping on the ends instead of a wire. When I recovered them I used old brazing rod (cleaned off the flux) and it worked perfectly.
Old Nov 5, 2017 | 10:40 PM
RAMBOW's Avatar
Ben
Seat-Guy ;-)
I toss them in 99% of the cases- unless they are absolutely mint- they can get really brittle and snap, and I have seen them get shoved up through the upholstery on a couple occasions- so its not worth the risk for me to put them back in...
I put new burlap down over the springs w/ a jute decking pad ontop of that (GM used a similar setup in most years).
Sebambam
Jul 3, 2017 02:42 PM
rcktdoc
Nov 8, 2013 04:51 AM
ros6872
Aug 28, 2012 09:43 AM
507OLDS
May 9, 2012 06:56 AM
WTony
May 20, 2010 02:44 PM
