DIY Backseat Bench Seatbelts
Old Sep 18, 2023 | 09:05 AM
MNtoTX1985's Avatar
Hey all,
I am trying to get an idea on what type of seatbelts I can install on my 1968 Cutlass S. Anyone have any suggestions for possible three-point seatbelts or harnesses as I want to bring my young kids into the car, but I currently do not even have a single lap seatbelt in the backseat. Any and all suggestions would be greatly appreciated my backseat is bench!
Thank you!
Old Sep 18, 2023 | 09:22 AM
lshlsh2's Avatar
71 cutlass convertible
Are you sure the seat belts are not pushed down into the seat. I am sure some one has belts you can purchase if you start a parts wanted thread.
Old Sep 18, 2023 | 09:24 AM
lshlsh2's Avatar
Not sure if shoulder belts were an option in the back in 68. You may need to make something custom.
Old Sep 18, 2023 | 09:34 AM
MNtoTX1985's Avatar
great, thank you! I tried checking to see if they were pushed back into the seat this morning but I didnt put too much time into it.
Old Sep 18, 2023 | 09:56 AM
They were not. Most car owners did not opt for 3pt belts in the front either.
Old Sep 18, 2023 | 10:04 AM
All 1968 Oldsmobiles were federally required to have lap belts for every seating position. Non-convertibles were also required to have shoulder belts for the outboard front seat passengers. Outboard rear seat passenger seatbelts were a factory option and the hard points for those belts exist in the car. None of the factory belts were three point inertia reel belts. The shoulder belts were totally separate from the lap belts with dedicated buckles and straps. I would be wary of aftermarket three point belts that do not attach to the factory shoulder belt hard points.
From the Fisher Body Manual
Old Sep 18, 2023 | 10:09 AM
Sorry, that is not correct. Front shoulder belts were a federal requirement for the outside passenger positions starting Jan 1, 1968. Olds incorporated them at the start of the 1968 model year. Rear shoulder belts were available under RPO AS5. Note the front shoulder belts in the Standard Equipment column on the left. This is from the 1968 SPECS booklet.
Old Sep 18, 2023 | 10:43 AM
Sorry memory fade, I thought the first year was 69 for the Fed Mandate.
miksan
Nov 7, 2022 02:56 PM
Phoenix8990
May 18, 2020 05:44 AM
442Harv
Brakes/Hydraulic Systems
Jun 5, 2015 09:57 PM
stonecad
Apr 14, 2014 04:34 PM
Pseudonym
Jan 3, 2011 01:51 PM
