1968 Cutlass Manual Console Overlays
Old Jan 3, 2023 | 10:27 AM
Bullwinkle's Avatar
Has anybody found manual console “chrome overlays” to place over the chrome trim on the center console for a 68 Cutlass?
I have some pretty deep scratches and a little bit of pitting on the chrome trim. I found the entire console top plates available, but I would rather keep the stock ones. Also tried 0000 steel wool, and 500, 1500 and 2500 grit wet sanding on a small test area. The scratches are too deep.
If no top plates are available. Who have you all been using to re-chrome interior components lately? I need to do bumpers and mirrors too. The top plates are cast, I believe, so no “plastic chrome”.
Thank you
Old Jan 3, 2023 | 12:50 PM
allyolds68's Avatar
Thank you
The only thing I've seen are the Part Place repro ABS top plates, glove box cover plates, and 4 speed overlay plates.
https://www.thepartsplaceinc.com/product/1968/1968-oldsmobile-cutlass-442-f85-manual-console-forward-top-plate-gm-386409-589087/102569
https://www.thepartsplaceinc.com/pro...k-chrome/93750
https://www.thepartsplaceinc.com/product/1968/1968-oldsmobile-cutlass-442-f85-manual-console-4-speed-pattern-emblem-gm-586542/9872
Old Jan 4, 2023 | 07:47 AM
Bullwinkle's Avatar
Thank you, I saw those prior to posting. I’d rather refurbish the originals, as they really aren’t in that bad of shape. Just some scratches and very light pitting. I was looking for a less expensive solution.
Has anybody sent their top plates in to get re-chromed? Do you separate the chrome trim from the top plate or does the whole thing get chromed and then you paint the center section black? It appears as if the plate is all one piece.
Old Jan 4, 2023 | 08:05 AM
allyolds68's Avatar
It's one piece. The whole thing is chromed and then the center is painted. You will pay way more to get yours rechomed and you'll lose definition in the center ribs from the chroming process.
67abody
Feb 18, 2022 01:52 PM
HitTheHole
Jun 2, 2015 06:57 AM
bwayco
Nov 30, 2013 08:31 AM
jasm8
Aug 14, 2011 05:32 AM
71 Cutlass
Apr 3, 2011 03:16 PM
