Column Shift Lever
Old Oct 8, 2023 | 10:17 PM
ChrisH526's Avatar
Column Shift Lever
I just purchased a ‘65 F-85 and I’m looking for an automatic column shift lever. (NOS if possible).
Old Oct 8, 2023 | 11:54 PM
cfair's Avatar
Don’t want to bum you out, but don’t pass on a complete column that has the parts you want.
Sellers often have strong ideas about how granular they want to go with selling individual parts.
Chris
Old Oct 8, 2023 | 11:57 PM
cfair's Avatar
I just restored a couple of tilt & tele big car columns which share almost nothing with your A-Body column, but I can confirm that they’re very robust and don’t really wear out. The mechanical parts were very well made and the trim can be restored without too many troubles.
I got mine in good shape, but am just not a good painter, so I farmed out the repaint of the trim pieces (semi-gloss black or so) to a local body shop, It will be fun to see what they come back with. I’m sure it will be better than my rattle-can resto effort.
Cheers
Chris
Old Oct 9, 2023 | 07:01 AM
ChrisH526's Avatar
My column shift lever end is like an 8 ball. I found a turn signal lever on eBay for $35 and I wanted to find something that looks just like it.
Old Jan 24, 2024 | 12:11 PM
Oldpete98's Avatar
Hey Chris, (or anybody) Any luck? I have a clean 65' 98 LS and same problem with a faded dice cube for a ****. ISO in any leads~ Thanks
Old Jan 24, 2024 | 12:16 PM
Oldpete98's Avatar
Does anybody know what years and models this **** was used?
Old Jan 24, 2024 | 03:41 PM
ChrisH526's Avatar
None so far.
Old Jan 24, 2024 | 07:56 PM
cfair's Avatar
At least for the 65-66 big cars, I can confirm that the Tilt lever end and Turn Signal lever ends swap.
I’m 99% sure the column shift lever end will _not_ swap with either of the other two. There are 2 points of mismatch I believe:
1) outside diameter of the lever shaft
2) length of the shaft splines.
I can’t comment with any authority whatsoever on the Cutlass/442/VistaCruisers. I just don’t know much about A-bodies…
Chris
Old Feb 2, 2024 | 10:19 AM
Oldpete98's Avatar
Yes, I am learning it's pretty hard to find things for the big cars. I just got 2 used original hub caps on ebay. I needed one but got an extra for backup. Any good suppliers that you've used?
Old Feb 2, 2024 | 10:38 AM
ChrisH526's Avatar
I usually buy parts from Original Parts Group but I also buy from Fusick and eBay.
Old Feb 2, 2024 | 11:34 AM
Oldpete98's Avatar
That's all I have used. OPG for generics, Fusick limited, and $ Ebay seems to come through if you're diligent. Swap meet season is coming soon.Fortunately I'm pretty complete (but are you ever?) on my 98 lux. A far cry from all my Chevy experiences with everything readily available.. But now I'm into Olds and now looking for more to buy. How did this happen? lol
Toms cutlass
Dec 8, 2025 07:41 PM
Jim Kniola
Apr 4, 2022 07:01 PM
Mj119
Oct 3, 2021 10:18 AM
goldie442
Apr 26, 2014 10:53 AM
Rocketbrian
Oct 2, 2013 10:18 AM
