Dashpad Bead Moulding
Old Jun 26, 2023 | 11:30 AM
oletrux's Avatar
Is there a good method to install this stuff?
https://www.oldsparts.com/product/dashpad-molding/
I've worked trying to get it relatively straight until my thumbs are toast. Used the hot sun to try to soften it, but it still will not uncoil. I don't think those little plastic clips will hold it in place if I use the original holes.
Thx.
Old Jun 27, 2023 | 07:20 PM
70sgeek's Avatar
'72 Cutlass ragtop
maybe try heating it with a hair dryer? I bought a moulding kit a few years back essentially just for the clips - my original moulding was in decent shape but for some worn clips which weren't staying put in their mounting holes.
I do recall noting the kit moulding was a bit stiff and wouldn't immediately straighten out for mounting without some kind of help.
Old Jun 28, 2023 | 12:35 AM
Ap6954's Avatar
As noted warm the trim up and use the clips in new holes in the dash groove. If you pre drill a small pilot hole first in the dash groove it makes the clip push in a bit easier. Patience is the key.
Old Jun 28, 2023 | 05:06 AM
oletrux's Avatar
Thanks guys, it's in! You are right, patience is the key.
Eddie Hansen
Jul 13, 2022 08:53 PM
autocomman
Sep 16, 2015 12:51 PM
69ishHoliday
Jan 26, 2015 05:13 PM
Rocket331
Body work
Sep 18, 2012 04:00 PM
craftsmen22
Sep 28, 2011 04:57 PM
