Promlems to install boot since pinchweld is too low
Old Sep 27, 2011 | 01:17 PM
craftsmen22's Avatar
Cutlass driver in Germany
Hi,
on my 1969 Cutlass conv. I can't install the boot with the plastic to slide underneath. Reason is the pinchweld, on the driver side everything is okay, but on the passenger side, the pinchweld is almost sitting on the body, and it seems like glued, to the body. So I was told to get clips, but I am not able to install either, because once the clips are attached to the boot, I can't snag them on. So I wonder what do to the get the pinchweld a bit up, so I can slide the plastic underneath. Any help is welcome.
Thank you,
Tom
Old Sep 28, 2011 | 12:36 PM
--- push ---
Old Sep 28, 2011 | 12:46 PM
Lady72nRob71's Avatar
I have that same problem, but never had time to figure it out.
I need to find out HOW the moulding is installed first...
Old Sep 28, 2011 | 04:57 PM
rcorrigan5's Avatar
Randy C.
I don't know about verts newer than '69, but the pinchweld in both my '68 and '69 verts attaches the same way. See the Fusick catalog, part number D3685. There are supposed to be around nine or so of those clips that fasten around the perimeter of the well opening with a single screw. In reality, though, when I took both my '68 (Lansing car) and my '69 (Fremont car) apart, each only had 5 clips. Once those clips are in place, the pinchweld snaps in place over the clips.
I know on my '68 it didn't look like there would be enough room to slide the thin plastic pieces under the pinchweld (especially on the passenger side) but it all goes in. I had a little trouble at first with it coming out on the driver side but that problem went away once I stretched the boot through normal use.
The book says that some sort of sealant is supposed to go on under the pinchweld before you snap it in place. I didn't do that with mine. The car never gets wet, anyway.
I don't know how to solve the problem of not being able to get the plastic pieces under the pinchweld.
Randy C.
wisniows
Jul 8, 2015 04:09 PM
W30Olds
Jul 1, 2014 05:50 PM
ctrain22
Body work
Oct 9, 2010 01:46 PM
ctrain22
Paint
Feb 15, 2010 02:23 PM
