PDA
View Full Version : Major Builds & Projects
Pages : 1 2 [3] 4 5 6 7 8
  1. New VIN sticker...
  2. The 65 is done!
  3. Maybe one day 1968 442
  4. The '64 F-85 Truck made its Debut!
  5. 1973 oldsmobile revcon
  6. The old girl needed a "Heart Transplant"
  7. My 1972 base to 442 clone / Resto (lots of pics)
  8. New to group with with a 71 Cutlass
  9. '69 H/O Project
  10. 1972 Cutlass S rebuild Suggestions
  11. Weatherstripping removal/replacement
  12. Mission accomplished
  13. My Leaking A/C Compressor Project Is Growing & Growing!
  14. The wifes first engine/trans install.
  15. 69 Delta 88 Royale
  16. '64 SF Firewall-Forward Resto
  17. Getting my 1969 442 convertible back on the road
  18. pulling the engine-oil leak
  19. 1964 Delta 88 restoration
  20. Some assembly required...
  21. Here we go again . . .
  22. New Start for 71 W30
  23. 1969 Cutlass Hood Repair
  24. 1969 Cutlass Floor Replacement
  25. 71 Cutlass Body mount locations
  26. Repairing frame, replacing floor pans, and
  27. Adding factory options to my 67 CS Convertible
  28. Motor swap need advice asap ?
  29. Motor swap need advice asap ?
  30. 3 years to the day I brought it home progress..
  31. New project- 68 442 Vert
  32. 1967 Cutlass Supreme 330 radiator with A/C
  33. 1972 U code 455
  34. I've finally gone and done it
  35. Over heating issue
  36. 1970 442 Convertible Restoration
  37. 1970 Cutlass W-31 Frame Off Restoration
  38. Timing tool BT-11
  39. Holley sniper EFI, Coker firestone wide oval tires.
  40. Lack of Horsepower in 350 Rocket
  41. 68 Cutlass S Convertible Window adjustment help
  42. 68 Cutlass Power Window Help
  43. 442 revived, smashed, revived again and reborn!
  44. '71 442 almost done! ' thought I would share my story as well.
  45. My 1949 olds coupe project
  46. A different kind of build
  47. W31 Q-ship build
  48. 1970 442 455 build
  49. Wiring is started and windows pics
  50. 1969 Olds Cutlass Convertible Deck lid
  51. f-85 4 door Hot Rod?
  52. 67 442 body off frame
  53. 69 442
  54. Saving a 69 "racecar"
  55. The revamp Part 3
  56. 1965 Jetstar 1 Progress.
  57. Rear end and suspension
  58. 62 Jetfire 4 speed restoration
  59. Body is on!
  60. Shop in California
  61. johnnyolds442 1971 442 thread
  62. 67 Cutlass Holiday Coupe, 1 owner restoration project
  63. Paint is done!
  64. Update on the 65 progress!
  65. 1971 442 seat belt identification
  66. 1964 Cutlass and 1965 442 Restorations
  67. Body update!
  68. 72 Cutlass Supreme
  69. Dash Gauge Specs
  70. It's Build Time
  71. 70 442 post coupe restoration
  72. CNP project begins
  73. Progress report of my 65 442...with pics
  74. The Body Stays On This One Too, 1970 442 4 Speed Refresh, has morphed to a body off!
  75. 1972 W29 442 4 Speed Car project
  76. Vaccum/Fender help
  77. New Years Resolution - 68 Conv Frame Off
  78. Fix or replace rocker panel
  79. Fire in the hole...
  80. 1969 Oldsmobile W-31 "El Malo"
  81. Firewall
  82. NOP Near On Plug stand-alone ignition system
  83. 1970 W30 Project
  84. Bracket Help
  85. Firewall Repair
  86. Painting after sandblasting
  87. Parts car story!
  88. My 65 restore is back in gear
  89. 1970 Cutlass Problems With First Start After Complete Engine Rebuild
  90. 1970 Cutless
  91. Restoring My Rallye 350
  92. 70 442 interior restore
  93. whats it worth ---70 442 W30 rotten??
  94. 425 rebuild
  95. 455 Build
  96. How much $$ Rebuilt 455?
  97. 1959 Olds Super 88 (Inherited Beauty) – 12,685 Original Miles
  98. Tachometer- Needed on automatics?
  99. 78 olds delta 88 royale 350 rocket newbie
  100. 394 "Rocket" engine build
  101. Newbie tackling 65 Cutlass
  102. 67 Cutlass that begged to be saved!
  103. 71 Cutlass hood help
  104. My Rallye 350 F85 Sports Coupe Restoration
  105. 1970 Vista Cruiser Restoration
  106. 1969 442 project
  107. Position of fuel line above the frame at the rear axel
  108. 350 performance rebuild
  109. I'm back this time with a 73 Olds 98
  110. 69 Cutlass Supreme Holiday Coupe rebuild
  111. Granddaughter's first hot rod ( pedal car build)
  112. 1972 Flame Orange Supreme
  113. Power Seat Track assembly and trim.
  114. Rear window tracks '62 Starfire convertible
  115. 72 Delta 88 vinyl top
  116. Push rod question and suggestions please
  117. Rebuilding my first 1969 442 Convertible
  118. Dead Folks
  119. Happy 4th!
  120. 1957 Super 88 Project
  121. The underside of my roller rockers
  122. 70 Cutlass Pace Car project
  123. Rear window motor 68 S Convertible
  124. 1959 Oldsmobile Rocket 88
  125. Summer Goal - First Startup
  126. Repop door hinges
  127. 1967 Delmont 88 Exhaust
  128. Retain Original Parts?
  129. Rebuilt 455 Initial Startup/Mockup
  130. Frame
  131. fuel pump to block gasket trouble
  132. Almost finished
  133. Recommendations on a cam size
  134. OK it's wrecked
  135. 1970 Indy Pace Restoration
  136. 1971 Cutlass project
  137. 1970 Vista Refresh
  138. The repaint begins
  139. 1968 442 Convertible - restarting the 2013 project
  140. R 12 or R134A
  141. 64 cutlass convertible f-85 with ac heater core replacement
  142. Chemical dip
  143. 72 Cutlass Vert Interior Rehab
  144. Fuel injection/carburatored fuel tank
  145. Flexplate bolts
  146. 1968 Olds 442 Restomod Buildup
  147. 70 Cutlass Supreme restoration
  148. 1970 Cutlass S Restoration Project
  149. I've bought another '63 Cutlass
  150. 68 Red Cutlass Build
  151. Best place to buy restoration parts for my 66 olds cutlass convertible
  152. 70 Convertible
  153. 1966 Olds 98 Convertible
  154. 1975 Hurst/Olds W25 -Fe2O3 body and suspension!
  155. My last rebuild
  156. '60 Dynamic
  157. 67 f-85
  158. Bagging a 1986 Olds Custom Cruiser
  159. Attention 66 and 67 owners, anyone try the OPGI vinyl top & driprail mouldings?
  160. 72 Cutlass convertible added to stable
  161. 62 starfire 2 door coupe floor pan replace
  162. Rocket SS build
  163. 1969 w-30 next project
  164. My 75 Cutlass
  165. Sick Vista project W(ar)-Machine (Large Marge)
  166. Restoring 1970 CS on a limited budget.
  167. BIG Project 1966 442
  168. Diving into the deep end, replacing rear quarters on a 71 Cutlass Convertible
  169. SS1 rally wheels
  170. Crazy 1982 Olds!
  171. Manual to Power Steering
  172. chasis swap
  173. Summit discount codes
  174. 1964 Cutlass Hardtop
  175. 442 body issue
  176. The NOS 442
  177. 1970 Garage Find
  178. 67 442 project, long awaited.
  179. 60 dynamic in for bodywork over winter
  180. 1956 88 4-Door
  181. What's this bracket??
  182. Mondello. Buyer beware👎
  183. Making progress
  184. 66 F85 back yard find
  185. Manual bucket seat to power seat conversion.
  186. 69 442 starting new build
  187. 1972 442 conv progress
  188. Converting Non-AC 1968 442 to AC Car (OE System)
  189. 1970 442 4 Speed Restoration
  190. 455 swap into Cutlass
  191. Saved & Restored 70 Cutlass W31
  192. Rear Control Arms - Reproduction or Originals ??? - '70 442 W30
  193. 64 Cutlass Restoration
  194. 76' Cutlass Gran Turismo
  195. The revamp Part 2
  196. 1972 cutlass s
  197. 1972 Hurst Olds Frame Off Restoration
  198. My 1984 Delta 88
  199. 68 Cutlass Progress
  200. Progress on my '68 442 Convertible
  201. Starting restoration of parents' 1957 98
  202. Roll over protection and shoulder harness project
  203. 69 Convertible Resto mod Project
  204. Hello - Update
  205. 1969 Oldsmobile Cutlass S Convertible project....
  206. Rotisserie Help
  207. The Official 1970 442 Convertible Y74 Indy Pace Car Restoration Thread (Dr Mansell's)
  208. 1955 88 Resto
  209. Setting dwell on a non-stock engine.
  210. 1964 olds 98 rebuild
  211. 1940 Olds 2Dr Sedan Build...from scratch
  212. 72 restoration
  213. Red Inner Fender Restoration
  214. my 71 442 junk pile
  215. Finally got the startup video uploaded for my EFI project
  216. Tonys 72 Cutlass Restoration
  217. Almost done with EFI engine (long)
  218. 1966 F85 Restoration While Driving
  219. The 14 year old ordeal coming to a close.
  220. 71 Cameo White 442 Back from the Abyss
  221. 350 stroker build re assembly PS Pump issue
  222. fuel injection and stock exhaust manifolds
  223. 70' Cutlass-All Done......Finally
  224. 68 W-46 engine revival..... :-)
  225. 78 Cutlass Supreme Brougham Questions
  226. 72 A Body wood tip over Jig
  227. 73 Delta 88 Royale Restoration
  228. 64 Cutlass 455 swap in LA
  229. 1941 Oldsmobile series 98 restoration
  230. 1969 HO preservation
  231. 65 cutlass project
  232. My 442 Story
  233. Power door lock and power seat back release.
  234. Power window install.
  235. Rallye 350 Restoration
  236. About to start my 72 Cutlass Supreme
  237. Fuel pump whining
  238. 70 442 advice requested on how deep to go into rebuild
  239. 1971 442 4 speed save
  240. 1972 Cutlass Convertible
  241. Sicky cant stop: 70 Cutlass S project IRIS
  242. 4 Link Suspension and All Around Disc Brakes
  243. 69 w30 restoration
  244. Hood adjustment problems
  245. 1972 Hurst Olds
  246. 1972 covertible update
  247. 69 Cutlass spring cleaning 3/12-3/19
  248. 66 Done
  249. hot tanking and magnaflux
  250. 1955 Olds Super 88 Holiday 4 door hardtop
