78 Cutlass Supreme Brougham Questions
Old Jun 6, 2016 | 08:56 PM
Telamundo's Avatar
I just acquired a 1978 Cutlass Supreme Brougham. It is not running and needs a lot of work. I have started to make a TODO list. I plan on doing a full restoration from head to toe. Looking to see if there are any good websites where I can find item such as exterior and interior trim to brake and fuel lines.
Thank you in advance for any help provided!!
Old Jun 7, 2016 | 03:10 AM
1970cs's Avatar
Lansing built
Welcome to C.O. That era of car hasn't had a good following. Most of the mechanical pieces can be had at the local auto parts. You may be able to get a few items from G body parts.com FYI IIRC that is really a W body
http://www.gbodyparts.com/index.php?...b34e429ce96760
A donor car would be the best way to go. Or e-bay?
Pat
Old Jun 7, 2016 | 07:18 AM
CRUZN 66's Avatar
Olds Fever
Pat
1978 thru 1981 are A-Bodies not "W"
Old Jun 7, 2016 | 07:22 AM
CRUZN 66's Avatar
Olds Fever
Originally Posted by Telamundo
I just acquired a 1978 Cutlass Supreme Brougham. It is not running and needs a lot of work. I have started to make a TODO list.. Thank you in advance for any help provided!!
Welcome to the site... If you really plan on investing a lot of effort into your Cutlass, I strongly recommend that you purchase a Chassis Service Manual and a Fisher Body Manual... It will help make your task much easier...
wbluesky
24
Jul 7, 2014 05:01 PM
Wildcard
Nov 29, 2012 08:52 PM
69Rman
Mar 16, 2009 05:40 PM
POKANOKET
Jul 14, 2007 02:58 PM
<RonC>
Jun 22, 2004 12:36 PM
