1956 88 4-Door
Old Nov 27, 2016 | 02:48 PM
Ihatefiberglass's Avatar
1956 88 4-Door
Hey guys it's been a few years since I've worked on this project so I'm hoping I can get some extra help when I run into problems. The body is in excellent shape and I've had the engine/ tranny rebuilt but I still have a long way to go.
It's 1956 88 that's been In my family since it was new. It was stored around the 1970s in a garage while it was still running. I tore into it about a year ago and stopped to deal with other life things.
I plan on keeping it almost entirely stock. I had an over-sized cam put in the 324 that was designed for the stock engine and I would like to run duel exhaust. I notices in the frame there is a another hole for what I think is a second exhaust pipe. If I run duel exhaust would I need a "H" or "X" pipe?
Old Nov 27, 2016 | 04:31 PM
Rocketowner's Avatar
Welcome to Classic Olds.Car looks very solid ,must not be from The Northeast. Seems to be a regular "88" .Did it have the 4 barrel carburetor or 2 barrel?Not too many have one that age that's been in the same family since new.Most "50's owners hang out on the vintage Olds forum. Any problems you need advice with ,just post. Questions on Vintage Olds. And there's lots of knowledge about these cars,,and some guys that are eager to answer. Larry(Rocketowner)
Old Nov 27, 2016 | 04:37 PM
Welcome back, I moved your post to the Major Projects section. I would recommend an H pipe for your car.
Old Nov 27, 2016 | 05:15 PM
redoldsman's Avatar
Proud Viet Nam Veteran
With the X frame an H or X pipe is going to be difficult to install. Unlike the 54 and 55, the 56 does have the frame cut on the left side for dual exhaust since they were available in 1956.
Old Nov 27, 2016 | 05:33 PM
ignachuck's Avatar
Frank Ignachuck
Hard to tell from the pictures, but it looks like a Super 88 (emblem on the fender looks like a bullseye with the 88 in the middle) and the interior looks like my Super 88. If it is, it came with a four barrel carb. Dual exhaust was optional, and, as Redoldsman just stated, difficult to add.
Old Nov 27, 2016 | 05:48 PM
Tedd Thompson's Avatar
Not near as bad as the 54 55. The vacuum tank isn't in the way and as stated from Redoldsman above the frame is already cut for a passage way to the rear. Now if you add a H pipe then you would have troubles, bunch of stuff (mostly frame) will be in the way. A precut and bent exhaust system useto be available through Fusick but I don't know if they still have it in their catalog... Tedd
Old Nov 28, 2016 | 05:54 AM
You are right, the car spent most of its life in the mid-west. It is just the base model 88 with a 4 barrel carb.
cobalt
Mar 3, 2013 08:10 PM
The_German
Jan 9, 2011 12:38 PM
Hurst
Cars Wanted
Nov 24, 2009 08:45 AM
56oldsnub
Dec 18, 2008 08:25 AM
bobs88
Feb 2, 2008 09:35 AM
