1972 Flame Orange Supreme
Old Aug 13, 2017 | 05:39 AM
ajr2820's Avatar
Here is what I am starting with. I am the 3rd owner. The guy I bought it from had her for 9 years, but could never get started restoring her due to health issues. The original owner was his next door neighbor growing up. The original owner replaced the vinyl in the early 80's and did a crappy job...so we have the a pillar and rear window rust as a result. The frame is solid with almost no rust as far as I can see so far. The interior is in decent shape. It's all coming apart nicely so far.
Old Aug 13, 2017 | 07:05 AM
scottv442's Avatar
Maintained
Welcome to CO
I had that same interior in my first car long ago. Sure brings back memories. I drove it daily for three full years back east and every spring had to fix the rust.
Damn salty roads.
Looks like you have the typical rust problems, but nothing that can't be fixed.
Your roof is the worst area as I'm certain theres more rust under the supports you can't see. Get a donor roof and replace yours if you can.
Cheers
Old Aug 13, 2017 | 11:55 AM
stevengerard's Avatar
nice car, buckets and sport mirrors not options on a Supreme and the 8-track and ac are nice options as well
Old Aug 13, 2017 | 01:55 PM
oldspackrat's Avatar
I have some nice A pillars on parts cars here in Indianapolis that I can cut out for you. I do not have any Supreme parts cars right now.
Old Aug 13, 2017 | 02:10 PM
What? Is that a typo? Those were indeed options on a Supreme.
Old Aug 13, 2017 | 04:45 PM
Yes, typo, meant to say "nice" - that's why I said "as well" in the next sentence
Old Aug 14, 2017 | 09:26 AM
4speed455's Avatar
Actually the bucket seats were standard on the Supreme. The console was an option though. That's why you see a lot of Cutlass Supremes with buckets and a column shift.
Old Aug 16, 2017 | 05:19 AM
ajr2820's Avatar
That would be great! When I get it torn down a bit further and can see the extent of the damage, I'll contact you.
Old Aug 20, 2017 | 07:38 AM
ajr2820's Avatar
What are you asking for that a-pillar? Will be ready for it shortly. I'm taking the windshield out this morning to get the full picture of the damage. Fortunately, the rust doesn't appear to have spread too far. The pillar seems sound structurally. Likely just needs patched.
Old Aug 20, 2017 | 11:27 AM
I usually get $75 / A pillar. Get a couple pictures of exactly what areas you need and I'm sure we can make a deal.
Old Aug 21, 2017 | 04:46 AM
ajr2820's Avatar
I'll get some pics together tonight. Thanks!
Old Aug 21, 2017 | 04:54 AM
ajr2820's Avatar
I have the interior completely out of the car. I have some light surface rust on the floorboards. No holes and very solid. It is concentrated in the front seat footwells. I will sand it all down and remove all the rust. What is the best way to treat this area? Self-etching primer and paint? POR15? I don't care about looks since it will be hidden under the carpet. I just want to be sure to keep the rust at bay. Suggestions?
Old Sep 8, 2017 | 11:30 AM
johnrossjdr's Avatar
Like the orange/white combo!
I have no issue with POR15, but would recommend to use the POR metal prep and primer as well. Think most folks problems come because they start mixing products especially on the low end where folks just buy everything from a Lowes or Home Depot and end up with a rustoleum primer, valspar rattle can and a krylon clear rattle cans. And yeeeees, speaking from my past as thats exactly what I did on an old POS I had. Flaked off within months despite the prep actually being decent. Redid with single line of products, lasted for 2 years till sold with no issue.
Let me check this with, I am a newbie, I am not a pro by any measure, and wait for much smarter opinions from others.
Looking forward to seeing the after pics and hope you stick with the orange!
Old Dec 8, 2017 | 07:35 AM
ajr2820's Avatar
I have started doing some body work. I am right now focusing on the sail panels and thhe rear window channel. I have the sail panels taken down to bare metal. Being that the car is inside my garage, is there something I should do to keep them from rusting or will they be OK for the time being?
Old Jan 19, 2018 | 10:47 AM
ajr2820's Avatar
Spring Removal
OK. It's been a while since I've posted. I have the body off the frame and am working on disassembling the front suspension. What is the best method to remove the front springs? Keep in mind that the body, engine, etc. are no longer there to provide weight while unloading the springs. Any recommendations on a good spring compressor?
Old Oct 8, 2018 | 06:04 AM
ajr2820's Avatar
It's been a while since I've updated. Here are some pics. I currently have the transmission on the bench for a rebuild and installing a shift kit.
Old Oct 8, 2018 | 06:14 AM
RetroRanger's Avatar
72 Olds CS
Looks like your making some good progress the frame looks great
Old Dec 12, 2018 | 03:09 PM
AJFink's Avatar
Looking good take your time and you will have a really nice car. Your doing it right.
Old Dec 13, 2018 | 04:17 PM
11971four4two's Avatar
MOTORHEAD
Wow rolling stock looks "nice"
Any plans for body / paint??
Happy holidays
Old Dec 14, 2018 | 04:52 AM
ajr2820's Avatar
Splitting time between the body and engine. I need to update some pics. I have replaced the upper cowl and am in the process of repairing the windshield channel. I have my 455 block torn completely down as well.
Old Dec 14, 2018 | 11:08 AM
MOTORHEAD
455 is a good thing! Cost to rebuild a 350 Olds is about the same$$$. Are you thinking about painting the car orange again? My cutlass supreme was changed from flame orange to silver paint.
Cheers
b
Old Dec 27, 2018 | 05:43 AM
ajr2820's Avatar
**Updates**
Windshield channel patch mocked up. New cowl top already in place.
Windshield channel glued and tacked in place.
Next up...the rusty A-pillar.
455 block stripped down.
New Wiseco +15.0cc pistons! The nodular crank, new H-beam rods, and the pistons are off being balanced!
Old Feb 20, 2019 | 05:29 AM
ajr2820's Avatar
**Further updates
Old Feb 20, 2019 | 05:48 PM
72 Olds CS
the manifold looks real nice w the edlebrock and torker highlighted
Old Apr 2, 2021 | 06:26 AM
ajr2820's Avatar
Been a while since I've updated. Here are some progress pics.
Old Apr 2, 2021 | 06:32 AM
ajr2820's Avatar
Old Apr 2, 2021 | 12:16 PM
My442's Avatar
Thumbs up
Nice work!
Old Apr 2, 2021 | 02:07 PM
72Pumpkin's Avatar
You are doing great taking on the body work. Where did you get your replacement sheetmetal? how was the fit?
Old Apr 3, 2021 | 06:49 AM
ajr2820's Avatar
I don't recall where I bought the sheet metal from. There are multiple options online. The fit was good with the A-pillar, the deck fill panel was decent. It required some minor tweaking. All the work on the sail panels was done from scratch. No panels exist for those.
Old Dec 17, 2021 | 09:11 AM
ajr2820's Avatar
Work update.
Driver side rear quarter arch
Driver side front quarter arch
Patched driver side front quarter arch. Sheet metal from the rear of the wheel arch from right front fender
Patch cut for driver side rear quarter arch. Sheet metal from front of the right fender.
Patched driver side rear quarter arch. Sheet metal from front of the right fender.
Old Jan 3, 2022 | 06:33 AM
  #31
ajr2820's Avatar
Reworking the wheel arch. Angle was a bit "off" and was bothering me.
Added a little filler
Sealed with epoxy primer
Firewall smoothed out
Old Jan 3, 2022 | 06:55 AM
  #32
72 Olds CS
Looks good youre making nice progress!
thanks for posting pics.
Old Jan 4, 2022 | 03:43 AM
  #33
Just found your thread. Very nice work. I had heard that it was possible to use parts from opposite fenders to repair others. I see you have done it. Excellent!!
Old Dec 8, 2022 | 06:26 AM
  #34
ajr2820's Avatar
Anyone ever use the Raptor bedliner to coat the underside? Looking to put it on with a slight texture and as thin as possible while still providing protection. Any tips or suggestions?
Old Jul 18, 2023 | 12:11 PM
  #35
ajr2820's Avatar
Underside coated with a fine coat of Raptor Liner.
Firewall closed up. Will be going with an aftermarket AC.
Raptor Liner inside trunk.
Recoated with epoxy.
Coated with Slicksand. Glazing low spots with filler where needed....not many areas. Sanded flat with 180. Will be recoating and blocking with 400 and 600 soon.
Old Oct 23, 2023 | 06:38 AM
  #36
ajr2820's Avatar
Engine, transmission and exhaust installed. Body will soon be reunited with the frame soon!
Old Oct 25, 2023 | 05:29 PM
  #37
Funkwagon455's Avatar
Subscribing, looking great!
Old Oct 26, 2023 | 02:32 PM
  #38
BackInTheGame's Avatar
You've got Mad Skills!! What Great Work! I love watching body work come together. Keep it up!
Old Oct 27, 2023 | 07:21 AM
  #39
ajr2820's Avatar
What am I doing wrong here? The lower bracket for the alternator is sticking out further than the top bracket. All the brackets, pulleys, etc. came off the 350 that was originally in the car.
Does the fact that the BB is taller than the SB come into play here? If so, can I just put a spacer between the alternator mount and the lower steering pump bracket? If I disconnect that and swing the alt bracket in line it looks like there is 1" gap.
Old Nov 19, 2023 | 05:21 AM
  #40
ajr2820's Avatar
MIlestone reached!
