The repaint begins
Old Apr 2, 2017 | 04:29 PM
eric66's Avatar
The repaint begins
Hey,guys the repaint have started on my 70 Delta 88.
Old Apr 2, 2017 | 04:32 PM
coppercutlass's Avatar
Chevy budget Olds powered
Mine is getting close to paint. Im checking in to follow along.
Old Apr 2, 2017 | 06:01 PM
Funkwagon455's Avatar
Looks like a solid foundation for the location... Lots of real estate!, It should look great!!!😀😀
Old Apr 3, 2017 | 05:33 AM
Oh yeah!
Old Apr 3, 2017 | 07:20 AM
CRUZN 66's Avatar
Olds Fever
That's the only way to do it correctly... Right down to the metal, to see what you really have to work with... Looking forward to seeing the finished project...
Old Apr 3, 2017 | 07:56 AM
TripDeuces's Avatar
Looking good!
Old Apr 4, 2017 | 07:22 AM
snail's Avatar
69 Delta Custom Holiday
Thumbs up can´t wait to see her finished...
lot of work - but I am quite sure the result will be worth all the efforts !!!
What color have you Chosen for her?
Old Apr 4, 2017 | 11:23 AM
eric66's Avatar
Same color
Old Apr 5, 2017 | 07:32 PM
jfb's Avatar
jfb
make sure you get the longest blocks possible for block sanding and finish it according to the paint line your using. Do not mix paint line products do the homework to ensure a great finished product. I would also suggest going in a x pattern for sanding.
Old Apr 8, 2017 | 04:38 PM
eric66's Avatar
​​​​​​ Thank you for the advice I will follow your instructions.🤔😉
Old Apr 19, 2017 | 06:03 PM
eric66's Avatar
The repaint begins
Old Apr 19, 2017 | 06:38 PM
RocketRonnie's Avatar
Are you doing this at home? Great job what brand primer did you use, I'm subscribing. What brands do you like using.
Old Apr 19, 2017 | 08:15 PM
JFB the only reason you don intermix products is for warranty and for the do it your selfer there is no warranty. That pretty much applies to shops. I have use ppg paints over dupont primers and sealers etc ect no issues. proper techniques go a long way. On a regular basis at the shop we paint over factory finishes and in some cases other finishes other than factory. Its common foder in a collision shop. Lets just say getting a Jobber to pay up on warranty is a slim and none chance. been there done that and they brought 4 diffrent rep techs sanded an entire bedside found a bs. reason to not pay up and we had to re spray the bed for nothing. The only time it really matters is when spraying. lets say dont spray ppg on top of a dupont sealer if you are doing the sealer and spraying the paint withing the flash times . Now if that sealer fully cures and is dry you can top coat with any other paint. When working within flash times its necessary when its sealer and base coat. I have sprayed transtar clear over ppg base coat with no issues and thats working within flash times but with clear its a little diffrent as base coat the solvents evaporate faster than sealer.
Also the X pattern sanding is kind of a generic term and if the whole car is done that way it will end up wavy. You need long even strokes that follow the body's contours.
No x pattern sanding on this 67 i did for member 67cutlassfreak and all the panels got a skim coat of filler end to end to make it as straight as possible.
Old Apr 19, 2017 | 08:22 PM
I've had good sanding results with Durablocks... I have several lengths/contours
Amazon Amazon
Old Apr 19, 2017 | 08:31 PM
They (durablocks) are good for flat surfaces but to do it right you need good semi flexible rigid blocks. The block im using on the 67 i put a picture of is actually the foam edges they ship hoods with. I have them in many lengths and they do the job. This is the expensive tool for my re purposed foam edge gaurds. I have dura blocks but use them for initial cutting then fine tune with a flexible block to shape the panel.
https://www.summitracing.com/parts/a...FZ21wAodXx8Dbw
Old Apr 20, 2017 | 09:49 AM
eric66's Avatar
The repaint begins
I'm using Transtar primer and sealer. My friend is showing me how to do things I'm getting plenty of experience along with plenty sand in all kinds of places.This at his shop.
Old Apr 20, 2017 | 11:23 AM
Transtar is good stuff. Car is coming along nicely.
Old Apr 20, 2017 | 02:22 PM
eric66's Avatar
Man that quarter panel is smooth
Old May 12, 2017 | 11:52 AM
eric66's Avatar
Old May 12, 2017 | 03:57 PM
eric66's Avatar
More sanding 🤔😑
It's getting there, front bumper must come!
Old May 12, 2017 | 05:09 PM
Nice work, its coming along nicely.
Old May 12, 2017 | 07:03 PM
Nice progress. i just got done blocking my entire car. Your car is coming along nicely.
Old May 27, 2017 | 07:29 PM
eric66's Avatar
A update on the repaint
Old May 27, 2017 | 09:21 PM
Looks very nice. That's one of my favorite Delta body styles.
Old May 28, 2017 | 05:10 AM
eric66's Avatar
Thank you
Old May 28, 2017 | 09:12 AM
Very nice !!!
Old May 28, 2017 | 09:27 AM
eric66's Avatar
Very nice !!!
Thanks you how your car coming!
Old May 28, 2017 | 09:28 AM
eric66's Avatar
Are you going to Lansing this year?
Old May 28, 2017 | 09:34 AM
I dont do many shows. Mainly drag racing but the car is pretty much ready to spray.
Old May 28, 2017 | 10:50 AM
eric66's Avatar
Please show off your painting skills, if they are good as your body work it'll look great
Old May 28, 2017 | 06:15 PM
  #31
Thanks. I'm handing the trigger duties to a really good friend of mine . I don't like painting. Although I will be laying down the stripes. The last car I painted was 3 years ago . I don't like painting as much as i like doing the metal work.
Old May 31, 2017 | 02:04 PM
  #32
Gerald Nickels's Avatar
Been watching great job. Why is the mirror still on you have the door panel off.
Old May 31, 2017 | 04:07 PM
  #33
eric66's Avatar
Every bolts on this car was Adventure in patience and grit,after cutting a couple fingers and scraping knuckles it still will not come off.. I will have to live with that mirror staying on door. My friend who is a 30 year body man said he never seen anything like that before.
Old May 31, 2017 | 04:56 PM
  #34
Dumb question but are they reverse threads ?. I have done many mirrors where they are reversed threads.
Old Jun 3, 2017 | 10:41 AM
  #35
eric66's Avatar
It just spin no matter what we tried..
Old Jul 26, 2017 | 05:01 PM
  #36
eric66's Avatar
Old Jul 26, 2017 | 05:19 PM
  #37
eric66's Avatar
Old Jul 27, 2017 | 05:18 AM
  #38
Man that looks AWESSOME!
I love the wheels.
Old Jul 27, 2017 | 11:28 AM
  #39
snail's Avatar
WOW !!!!
Very, very nice !!!
Old Jul 27, 2017 | 04:56 PM
  #40
eric66's Avatar
I love the wheels.
