1970 Cutlass Problems With First Start After Complete Engine Rebuild
So I have a 1970 Cutlass (to be specific, the block is '70 and the heads are '72 7A's) 350 4bbl. I rebuilt the engine with pretty much all new parts except for the valve train. This is my first time doing a rebuild so I'm learning as I go. The car turns over, sounds like it wants to start but won't start up. I set piston 1 to TDC, I get a lot of backfire and coughing depending on where I have the rotor pointing (I've tried pointing it in different directions trying to find the right spot to start it up). Any suggestions would be appreciated. Thank you!
Might be a good idea also to list exactly everything you did on the rebuild. Timing is a common culprit but other things may have changed if heads were planed or block decked. Remember Dist turns counter clockwise also.
pfergy600
Feb 23, 2015 06:44 PM
Jonmueller1
Dec 20, 2013 07:27 AM
emarkay
Dec 8, 2004 08:23 AM
