69 Cutlass Supreme Holiday Coupe rebuild
Old Aug 24, 2017 | 05:04 PM
dogpatchcustoms's Avatar
Well, i went and did it.. Towed home my new olds project. Havent had one since 98....
picked this one up in southern Ohio, in pieces. Has had new Quarters and floor pans installed previously, i will be taking it down to metal again to make sure the body work is going to last before paint.
I have partially decoded the tag at tag decoder.com but could use some help on the rest. Here's what i have so far , and please feel free to correct or add to it, thanks George
1969 Cutlass Supreme Holiday Coupe
born 4th week of Feb.
Fremont Ca.
Glade green
parchment vinyl top
Old Aug 24, 2017 | 05:56 PM
RetroRanger's Avatar
72 Olds CS
looks to be pretty solid will you repaint in the green I like that color.
Old Aug 24, 2017 | 09:14 PM
yes going with the green paint and white buckets and door panels
Old Aug 27, 2017 | 04:14 PM
a little more done today
sand blasted the firewall and dash area, as well as some small parts. Upper and lower control arms. Blasted and primed the deck lid. Next up blasting the frame and replacing the rear cross section, original was thin on one end.
Old Aug 29, 2017 | 04:56 PM
shiny
cleaned up nice...
Old Oct 7, 2017 | 12:47 PM
engine
picked up what appears to be a,
lansing built 70 350,
today out of a running driving n.o.m. 73 cutlass. tearing it down next to do a re fresh on it. loosing the egr. intake and hei dist.
Old Oct 30, 2017 | 12:32 PM
leaning tower of olds
strap'd upright to do some under detailing
Old Nov 25, 2017 | 02:16 PM
Restomod69's Avatar
Never seen it done that way before. Whatever it takes right!
Gearhead442
Sep 6, 2023 05:30 PM
coldfire
Aug 13, 2019 08:08 PM
overmyheads
Oct 21, 2016 12:06 PM
1970w30
May 24, 2011 07:31 PM
oils66
Nov 25, 2009 08:25 AM
