69 Cutlass Supreme Holiday Coupe rebuild
Well, i went and did it.. Towed home my new olds project. Havent had one since 98....
picked this one up in southern Ohio, in pieces. Has had new Quarters and floor pans installed previously, i will be taking it down to metal again to make sure the body work is going to last before paint.
I have partially decoded the tag at tag decoder.com but could use some help on the rest. Here's what i have so far , and please feel free to correct or add to it, thanks George
1969 Cutlass Supreme Holiday Coupe
born 4th week of Feb.
Fremont Ca.
Glade green
parchment vinyl top
Fremont Ca.
Glade green
parchment vinyl top
a little more done today
sand blasted the firewall and dash area, as well as some small parts. Upper and lower control arms. Blasted and primed the deck lid. Next up blasting the frame and replacing the rear cross section, original was thin on one end.
engine
picked up what appears to be a,
lansing built 70 350,
today out of a running driving n.o.m. 73 cutlass. tearing it down next to do a re fresh on it. loosing the egr. intake and hei dist.
