Diving into the deep end, replacing rear quarters on a 71 Cutlass Convertible
Old Jan 3, 2017 | 06:30 PM
lshlsh2's Avatar
71 cutlass convertible
I am going to try and replace my quarter panels. I have never tried to do anything this involved before. But everybody has a first time. I will add pics in the near future. I just got some patch panels cut and sent to me from a rust free car. I am hoping to get one side done before spring. I can weld but not great. I have an old fender that I am going to practice on before starting on the quarters.
My plans
1 Clean garage so i have as much room as possible
2 Drop gas tank and take off rear bumper
3 Start sanding to find out where all the rust is
4 Cut out and replace the panel
5 Try and avoid to many MAW
Any pointers? Am I missing something?
My biggest problem is that I sometimes rush and get in a hurry. I need to force myself to take my time. The car is a driver. I am hoping that I might inspire someone else to try. Hope I don't drown.
Old Jan 3, 2017 | 06:48 PM
m371961's Avatar
Are you doing quarters or just panels? Big difference. Not that I have anything to offer, but curious and want to see progress.
Old Jan 3, 2017 | 06:54 PM
lshlsh2's Avatar
Patch panels in the quarters. Mostly around wheel well and behind the wheels and drop offs.
Old Jan 4, 2017 | 12:48 AM
VI Cutty's Avatar
Definitely interested in following along any documentation/photos you share of your project. I'll be doing similar repairs to my '71 at some point in the future.
Old Jan 4, 2017 | 07:53 PM
tomsw31's Avatar
You may want to consider replacing the entire quarter panel since they reproduce the full panel. The reason that i suggest this is that you may find that "chasing" patch replacement may be more involved than you think and at the end of the day it could take longer and the result not as good as full replacement. I have welded the partial quarter on a hardtop and it was alot of work. They do not make the full quarter for the hardtop or that would be the route i would have taken.
Old Jan 5, 2017 | 06:07 AM
Oldsmaniac's Avatar
Recently put quarters on a 72, went pretty well. Remember less welding less seams to bondo. Here is a link to the build. https://classicoldsmobile.com/forums...-72-442-a.html
And a couple of picts
Old Jan 5, 2017 | 04:35 PM
lshlsh2's Avatar
I really did not want to do the entire quarter. It is only really bad around the wheel well and behind the wheel. The patch panels I got were cut from another car. It may end up to be more work but it is what I want and try and do. First part cleaning garage will be done this weekend, I hope.
Old Jan 5, 2017 | 06:04 PM
cdrod's Avatar
Rodney
Olsmaniac:
I'm knee deep in quarter replacement as well and curious to know how much of the original door jamb you kept; or did you replace the jamb as well? Any pics of the jamb area showing where you cut? Thanks!
Rodney
Here's a pic of my progress.
Old Jan 5, 2017 | 06:22 PM
Oldsmaniac's Avatar
I removed original quarter wrap around to door jam as the replacement came with that and just duplicated the factory setup there. All the picts I have were in thread posted above I mean the link to the build.
Old Jan 5, 2017 | 06:38 PM
cdrod's Avatar
Rodney
Oldsmaniac:
Sorry, I missed the link. I'll go check it out and thanks for sharing.
Rodney
Old Jan 5, 2017 | 06:51 PM
Oldsmaniac's Avatar
Originally Posted by cdrod
Oldsmaniac:
Rodney
Any questions reply on that thread.
Old Mar 12, 2017 | 08:07 PM
Macadoo's Avatar
Larry, just wondering how it's going with the patch panels. I think I'm in the same spot as you. Had a small rust spot behind each rear wheel, went poking around, and now I've got a 5x6" piece cut from each side. I don't have replacements though, going to try and make my own. How is the outer wheelhouse where it joins with the skin? I'm going to have to replace a little of that too.
I'm new to body work, as well. Just learning to MIG weld. My welds are ugly but I'm learning to keep the metal cool.......very cool. Lol.
Old Mar 13, 2017 | 06:45 AM
lshlsh2's Avatar
Haven't done anything yet. All my plans were foiled by a list of honey-dos for the wife. Now with work picking up it may be fall before I get started again. To be fair most of the list of honey-does really need to be done. I just would have done them in a different order.
Old Mar 13, 2017 | 05:56 PM
Macadoo's Avatar
Yeah, I guess that stuff has to get done. Homeownership can be a full time job. I'm on spring break this week (but it's snowing like crazy) so i get to do what I want. Making this patch panel wasn't too hard. The hard part was getting the hole cut right. Dremel or angle grinder. I wish there was something in-between
The magnets help a lot.
Old Mar 14, 2017 | 04:19 AM
1970greensupreme's Avatar
Olsmaniac:
Rodney
I see this in my near future. I have been offered the right quarter as a NOS part for around 2K, If I could get a left and right for around 3K I'd probably do it
Old Nov 4, 2017 | 06:08 PM
lshlsh2's Avatar
Finally getting started. Cleaned out the trunk. When I got everything out, it is more rusty than I thought. Will be doing the trunk floor also. Got the bumper and trunk lid off. Side marker out.
Hope to drop the gas tank tomorrow. Pics in the next couple of days.
Old Nov 5, 2017 | 08:12 AM
lshlsh2's Avatar
Posting pics
Old Nov 5, 2017 | 03:10 PM
RetroRanger's Avatar
72 Olds CS
Larry and others w pics in this thread what are you using to cut the quarters off? When I did the floors in my car I started w a very thin cut off wheel ,but it was to imprecise, loud, dirty etc for working in the car. I switched to an air saw w short blade and found it easier to use and less messy, but I wonder if there's a better tool?
Old Nov 5, 2017 | 03:45 PM
lshlsh2's Avatar
Not sure what I will be using. Probably a combination of things dremel, angel grinder and a air cut off wheel, and a saw with a short blade.
Old Nov 5, 2017 | 03:56 PM
lshlsh2's Avatar
Got everything ready to start removing metal. Dropped the gas tank but forgot to disconnect the ground. If this is my worst mistake I will be very happy. Had trouble with getting the rear seat out. The bracket holding the wire on the passenger side was bent and couldn't get it out. At some point the rear window got busted because I found at lot of busted glass. Nothing interesting under the seat.
Old Nov 5, 2017 | 06:29 PM
Oldsmaniac's Avatar
I used the angle grinder with thin cutoff disc, worked very well and fast.
Old Nov 7, 2017 | 02:40 PM
lshlsh2's Avatar
Surprise found an older poor repair. Looks like someone just put metal over top of the rust then lots of filler.
Old Nov 7, 2017 | 02:43 PM
Cincinnati Rick's Avatar
Sounds about right.
Old Nov 7, 2017 | 04:22 PM
TripDeuces's Avatar
Watching
Old Nov 7, 2017 | 05:31 PM
cdrod's Avatar
Rodney
So far I've used a thin 4-1/2" cut-off disc on my grinder for most of the cuts and (don't laugh) a sawzall to finish up in tight corners where the grinder wouldn't fit. Cutting with the cut-off wheel is very dirty and all the sparks require alot of extra caution, but the cuts go pretty quickly.
Rodney
Old Nov 7, 2017 | 07:07 PM
72 Olds CS
ok thanks for the info guys, the cutoff wheel was quick but working under the dash w the sparks etc was to much, w the air saw (like a mini sawzall) it was easier and cleaner plus i could get closer to it without worrying about the flying debris
heres the saw i used pretty happy w it thin cut (proBably thinner than the thinnest cutoff wheel) easily as fast and less debris and no sparks)
link
Amazon Amazon
Old Nov 7, 2017 | 07:24 PM
lshlsh2's Avatar
Retro thanks for the link. I will keep it in mind. Have a dewalt sawzall also.
Old Nov 7, 2017 | 07:59 PM
steverw's Avatar
When i replaced the one on my 67, i used Harbor Freight spot weld cutters, they are cheap and work good. There were approx 150 spot welds. I cut it at the bottom of the sail panel just below the holes for the vinyl top trim. I had a nice used original panel, so it fell into place pretty good. Different year i know but pretty much the same procedure. Just behind the door i cut it at the bottom from the door jamb to the wheel well, leaving about an inch above the seam at the rocker panel. It was alot easier to cut the spot welds fender to rocker with the fender off as opposed to trying to cut them through the window access from the inside. It was my first time to replace a quarter, not difficult just time consuming. I actually enjoyed it, learning how.
Old Nov 8, 2017 | 08:01 AM
TripDeuces's Avatar
I used a cheap Harbor Freight nibbler. It works like a dream but it can get away from you fast so be patient and if possible use a guide/fence to keep it in place. Cutting disc work well to but be patient once again. Basically whatever tool you use you have to have a steady hand or make it steady somehow.
These are recent pics from my job. I also used the nibbler to final size the patch panel. Just cut down my fence and attached it to the back side of the panel and held it in place with simple C clamps. The Clecos are a nice addition for a one man band. I also used a HF panel flanging tool and spot weld hole make on this.
Old Nov 26, 2017 | 12:35 PM
lshlsh2's Avatar
Starting to remove metal.
Old Nov 26, 2017 | 02:10 PM
  #31
lshlsh2's Avatar
Another pic
Old Nov 26, 2017 | 02:22 PM
  #32
Oldsmaniac's Avatar
Cool, unfortunately this is the easy part! lol
Old Nov 26, 2017 | 04:30 PM
  #33
lshlsh2's Avatar
It is always easier to tear apart than put back together.
Old Dec 29, 2017 | 03:05 PM
  #34
lshlsh2's Avatar
Been able to do a little over the holidays. It is moving slowly, lots of spot welds and taking my time so I don't do anything stupid. I have to force myself to take it slow, my biggest problem is rushing. This is the biggest chunk of the elephant by far.
Old Dec 29, 2017 | 03:54 PM
  #35
Macadoo's Avatar
Pics?
Old Dec 29, 2017 | 04:26 PM
  #36
lshlsh2's Avatar
Will put some up tomorrow.
Old Dec 29, 2017 | 06:23 PM
  #37
Macadoo's Avatar
Cool. I really enjoyed the little bit of body work I did. Mostly because body work has always scared the crap outta' me. It took the mystery out of it. Well, at least SOME of the mystery, lol.
Old Dec 29, 2017 | 08:12 PM
  #38
steverw's Avatar
If your going to be welding that seam in the middle of the quarter, take it very slow as too much heat will spread into the surrounding area and warp the panel. Then you have that problem to deal with. Be patient and weld only about 1/2 inch then cool the area, move to the opposite end and do the same. The advantage of replacing the whole quarter is that the welds are all on the outer perimeter of the panel and less likely to warp, and a lot less body filler. There is some kind of metal adhesive that apparently works very well, another member used it, ?Copper Cutlass or Oldstata? Sorry I cant remember who.
good luck
Steve
Old Jan 1, 2018 | 05:45 PM
  #39
dc2x4drvr's Avatar
X2, that seam could show up in the paint as a shadow, better to fit the panel to the body lines.
Old Jan 27, 2018 | 02:26 PM
  #40
lshlsh2's Avatar
Life has gotten away and I've just gotten back to this. Here's a few pics
