1972 cutlass s
Old Sep 28, 2016 | 02:26 AM
Trevors's Avatar
1972 cutlass s
I have a 72 cutlass s I'm intending to buy a w34 455 out of a buddies 70 toronado. Also going to buy the th425 with it. Will this drive train fit? Thank you
Old Sep 28, 2016 | 02:52 AM
CutLS442's Avatar
Everything will fit with a little effort, but unless you are converting your Cutlass to a FWD, I would stick with a RWD tranny.
Morten
Old Sep 28, 2016 | 03:08 AM
Trevors's Avatar
So I'd need a th400?
Old Sep 28, 2016 | 03:20 AM
CutLS442's Avatar
Yes
Old Sep 28, 2016 | 03:25 AM
Trevors's Avatar
Thank you! I am not to famular with the trans option clearly hhaha, but what is your opinion on your average th350 behind a 455?
Old Sep 28, 2016 | 06:59 PM
2blu442's Avatar
Trevor, what's the story on the Toro? The Toro GT's have collectors value more than just the value of the engine. The W34 transmissions have a special code that's shown as OM on a tag on the driver side. The 455 has a better cam than the non-W34, but anytime you rebuild a 455 you can upgrade it to have more output than the W34 engine. So don't get hungup on it being a W motor, if the car is restorable its worth much more together as an original car than just an engine and transmission. John
Old Sep 28, 2016 | 10:43 PM
Trevors's Avatar
The car is way past the point of restoration, but the motor ran strong before it was pulled a few years back. Could use a full rebuild, and a good paint job. Was also looking into an upgraded cam. The only problem I am having is figuring out if I should get myself a th400 to live behind it or just stick with my stock th350. I've read up on It that the th350 can handle a mild built 455, so I'm thinking that I might just save the money and stick with my th350 until it goes then after that I will go with a sold th400. I'm open to any other ideas though. Also was curious on what cam upgraded cam I should look into. Thank you
Old Sep 29, 2016 | 07:24 PM
csouth's Avatar
If you buying a th400 will tie up funds and slow your enjoyment of the 455, I'd use the th350 until it goes out.
Old Oct 1, 2016 | 12:13 PM
2blu442's Avatar
Don't scrap the Toronado W34 transmission. There is demand for them and you or your buddy can sell to a Toronado collector or someone with a Motorhome that uses the Toronado drivetrain.
John
Old Oct 1, 2016 | 12:15 PM
2blu442's Avatar
If factory, the W34 transmission had the OM tag and should look something like this photo
Gotvette?
Jan 9, 2015 06:42 PM
travisbeamon
Apr 6, 2013 09:37 AM
Oldssupreme
Jan 14, 2013 10:08 AM
rallye350
Dec 23, 2009 08:11 PM
egknz
Oct 26, 2009 06:06 PM
