Power window install.
Old May 17, 2016 | 10:58 AM
geoff442's Avatar
I am going to install factory power windows in my 1971 Cutlass, does anyone know what size hole to punch out in the door and the body, also the location of the holes. Thanks
Old May 17, 2016 | 12:15 PM
jensenracing77's Avatar
Not sure if this helps but they are a couple pictures I had on my computer of a 70 SX that I parted out. I think I seen more information on this in the fisher body manual. I know I seen it someplace but not for sure it was the fisher manual.
Old May 17, 2016 | 01:02 PM
oldspackrat's Avatar
I removed a complete power window, lock, & bench seat from a '71 Supreme a few years ago & photographed the entire thing as I took it apart for an occasion like yours. Here is the link to the pix, good luck with the project.
Scott
http://s856.photobucket.com/user/old...tory%20install
Old May 17, 2016 | 03:41 PM
oldsconv's Avatar
i have a nice thorough procedure I can email if you want. Let me know your email address. I think the door is 2 inches and body is 2.25 or 2.5 inch hole [/U]. Those have factory dimples. You'll see 3 dimples on door. Center one locates the center of large hole and outer two are for screws that hold boot on. Body/cowl should have same 3 dimples but hole is bigger.
Old May 17, 2016 | 07:06 PM
Convertcrazed's Avatar
I'm ready to start my install and I have found a few helpful hints on the net with limited info....Scott, thanks for the pics and oldsconv, can you email your procedure to me, I can use all the help I can......thanks
Eric M
fishonbuzz@gmail.com
Old May 18, 2016 | 04:53 AM
geoff442's Avatar
Thanks for all the replys !!! I will be installing power locks also. I got the harness last night,it looks like from picture from oldspackrat that car has power locks. The harness I got looks to have one section cut off, I'm thinking it's the connector where the relay goes, the pics from oldspackrat show window and locks great pictures.
Old May 30, 2016 | 09:25 AM
geoff442's Avatar
Drilling body from inside car with door on
Here's what I did to drill out the body side for the power window and lock wiring. I carefully used a 2 1/4 metal hole saw for the large hole and a 1/8 drill for the retaining pins for the boot. In order to transfer the location dimples I used an angle die grinder with a corse 3m pad. Then I ground down the point of the dimple from the inside until it was eventdent that that high spot was wearing thin or went through. Then I took a small pointed punch, and tapped it and there was a small guide hole after that. I still have to do the door I plan on using a greenlee 2 inch punch.
File Type: jpeg
Old May 30, 2016 | 09:27 AM
geoff442's Avatar
Missing pic
Here's another pic I'm not that good with uploading.
File Type: jpeg
Olds luvr
Mar 19, 2015 09:34 AM
Bitburger
Feb 8, 2013 08:24 AM
f-85
Jan 16, 2012 06:10 AM
jugdish
Aug 18, 2011 09:57 AM
atkinsom
Mar 21, 2011 02:38 PM
