65 cutlass project
Old May 22, 2016 | 05:29 PM
junkman005's Avatar
65 cutlass project
hello im Eric , with a 65 cutlass that im starting to break down to swap out the olds 330 motor believed to have a crack block into a cylinder , so I'm going to put in a 72 olds 350 into the car
Old May 22, 2016 | 06:41 PM
stan 65 cutlass's Avatar
welcome eric, i have a 74 olds 350 in mine, fits the same, use all your old brackets for alternater etc, exhaust manifolds
Old May 22, 2016 | 07:23 PM
Its a pretty easy swap. Are you leaving the 350 pretty much stock?
Old May 23, 2016 | 01:36 PM
junkman005's Avatar
yep leaving the 350 stock , dont want a race car just a good cruzer . got to admit little worried about this whole swap been over 20 years since ive swapped a motor . going to try to take pics as i get going on it might be a kinda slow start here since we are supposed to have rain all week. getting my truck ready and going to pick up the new motor tonight
Old May 24, 2016 | 08:01 PM
junkman005's Avatar
ok well got a slow start today , removed hood and drained radiator and part way removed , battery out now and power steering pump almost removed. oh and new motor made it home !
Old May 27, 2016 | 04:00 PM
junkman005's Avatar
ok i got a question since im almost to the point of pulling my motor out. the new motor did not come with pully's so when i take mine off is there a special way to put the pully's onto the new motor to make sure things are right ? i believe they should work since im going from an olds 300 to an olds 350
Old May 27, 2016 | 05:29 PM
don71's Avatar
same but different
If I were you, don't mix and match pulleys and accessories. Use one or the other.
Try to keep one system together on your engine.
That means use all the 330 stuff if possible.
Old May 27, 2016 | 07:44 PM
Compare the lengths of the water pumps if your reusing all the 330 pulleys and accy brackets.
Old May 27, 2016 | 08:17 PM
junkman005's Avatar
well the 350 has no pulley's and the 330 has all pulley's and bracket's for alt and power steering and air conditioning. I just got done puling the 330 out of car , now gotta clean up engine bay , and fix exhaust and place pulley's and then install motor.
Old May 28, 2016 | 06:52 AM
therobski's Avatar
just like Don71 mentioned use all your 330 stuff you will be fine. I'm coming up to Milwaukee in July for the Car Craft Nationals!
Old Jun 1, 2016 | 09:15 PM
junkman005's Avatar
ok well heres the update pics to come soon , i just got the 350 in car tonight got 3 of the bell housing bolts in got both motor mount bolts slide into place. there a line coming from the transmission its metal then goes to rubber anyone know where that might go ? if went into the intake manifold on the 330 but i dont believe thats where its supposed to go and since there was so much other things messed up with the 330 leave me wondering.
Old Jun 2, 2016 | 04:57 AM
RetroRanger's Avatar
72 Olds CS
That line sounds like the trans modulator, it gets full manifold vacuum and controls trans shifting at part throttle
Old Jun 2, 2016 | 06:53 AM
It is the vacuum modulator line, one side connects to the modulator and the other side goes to manifold vacuum.
Old Jun 2, 2016 | 05:23 PM
junkman005's Avatar
thanks now i gotta figure out where the line goes that took the vacumm modulator spot belongs lol here some pics of progress
oldstofty
Jun 3, 2019 03:46 PM
Rickman48
Apr 9, 2012 04:50 PM
hubb_99
Apr 12, 2007 07:18 PM
tex70
Dec 18, 2006 12:59 PM
fin170703
Aug 17, 2006 04:59 AM
