1973 oldsmobile revcon
Old Aug 27, 2018 | 06:58 AM
Goodoldsreliable's Avatar
Talking 1973 oldsmobile revcon
I am astounded that i came across this treasure and hope that with the help of you all, i can restore it to its former glory.
Also, its got the 455 rocket and ive got it to run and it is smooooooth
I suppose that we should begin at the most pressing matter, there is no brake booster. I have tried the 1973 olds toronado booster and its arm is more than half a foot too short and the bolt holes dont match up. Anyone know where i can find this thing? It appears that this is an issue with these revcons, finding parts.
Old Aug 27, 2018 | 07:14 AM
redoldsman's Avatar
Proud Viet Nam Veteran
It would help is we knew what the car is. Is it a Cutlass, 442, Delta 88 or a 98? It should not be a problem finding a booster.
Old Aug 27, 2018 | 08:00 AM
It is a 1973 Oldsmobile Revcon 250
Old Aug 27, 2018 | 09:06 AM
don71's Avatar
same but different
Ok, so revcon is a motor home using the toranado drive train. The stepson of the airstream guy invented this lineup of motor home. I came across this old link listing some suppliers and owners.
http://www.policeinterceptor.com/revconlinks.htm
I'm going to guess this vehicle uses some custom and propriety parts. The booster is probably the easy one, but the rod a little more challenging to find. Hope someone can be of help to you, there is going to be some homework on this one.
Old Aug 27, 2018 | 09:21 AM
redoldsman's Avatar
I remember the motor homes and always thought they were cool. I guess I would never have considered them an Oldsmobile although they were Oldsmobile powered. Good luck with your search.
Old Aug 27, 2018 | 01:57 PM
Well i do happen to have the rod still, is there a good chance i can get one that bolts up and use the old arm? Are these brake boosters relatively possible to rebuild?
Old Aug 27, 2018 | 01:58 PM
Also i do believe this beauty only has around 40k original miles
dragline
May 11, 2019 11:53 PM
70-Olds-442-convt
Jan 9, 2017 11:26 AM
tru-blue 442
Jun 9, 2015 12:52 PM
72OldsRocketMan
Apr 18, 2014 03:28 PM
ElaineZ
May 8, 2004 08:57 PM
