- Another 69 442 Post resto
- Did Therobski lose his mind?
- rubber grommets
- 1972 442 convertible pro touring
- '65 F-85 Club Coupe
- 72 convertible top frame
- 70 442 Factory Burgandy mist 4 speed
- 1977 T top question
- '57 Body panels
- I'm back again lol
- My car!
- ignition rod 1970 cutlass supreme
- Convertible Top Frame Assembly Schematic
- Hurst Badge
- Axle question
- Mitchy 70 cutlass
- Nothing Major, just undertaking a project for all our 1976 guys
- What to keep and what to get rid of?
- Introducing "The Dirty Blonde"
- [new addition] 1969 442 4 speed
- On The Road
- beast 2.0
- Window squeak
- Engine and Engine Bay detail
- Sammy"s 70 Cutlass Convertable
- restoring my 1986 Oldsmobile delta 88 royale brougham two door
- 72 convertible top alignment
- Any harm in replacing with larger gas tank?
- !966 Toronado 425V8 rebuilt...need help
- My 64 Cutlass build
- 1968 Hurst/Olds
- The 'beast' progress ('62 f85)
- Green Turd Arrived, 72 442
- '66 Toro Build
- seals
- Rebuild on Stock 350 motor finally started
- Need 6" water pump
- 72 cutlass body weight..
- 1970 Cutlass Sup Convertible restore project
- 70 442 w-30 non air
- 1972 cutlass supreme convertible
- Could use some advice.
- The best
- shes finally legal
- Greg Godon's 69 442 Post
- 1967 442 Restoration - Driveshaft
- 67 Floor, frame, rocker rust work
- Bad day in the garage!
- This weekend progress 64 JS1 frame off restore
- Engine color
- 1970 olds delta gasser
- 1969 Oldsmobile Holiday S Coupe (rocket 350)
- Cleaning up my 83 H/O
- it's been a while!
- 1969 Cutlass Tribute Restomod
- 1957 olds 88
- 1969 Hurst Olds Convertible Tribute
- 1959 Super 88 Resto
- 1967 Delmont, bags and rims
- 1965 Jetstar 1
- Newer gas tank leaking
- 70 camshaft spacer?
- Driveshaft Loop
- 66 f85
- Bringing Frances back to stock
- 72 Cutlass
- The next project.. convertible top
- 68 H/O resto I recently finished for a friend
- My first Cutlass!!!!! 78' 350 Rocket.
- 455 in a 56?
- 1970-72 OAI hood stencils
- 350 olds in a 1980 c10
- New here and new project
- 1970 Olds 442 Restoration
- tuning the olds
- 1965 Oldsmobile F85 project
- nderise 70 w-30 restoration
- 1982 AMC spirit getting 1971 Olds 350
- My 1969 Cutlass Supreme Holiday Coupe
- 1970 442 Rear Bumper - Help ID something?
- 1966 442 Resto
- a/c firewall conversion
- Finally found time for the Olds project
- Olds Delta 1973
- 72 supreme rebuild
- '57 Heater/etc controls
- 1970 Street/Drag Project
- Rear window ledge
- What electic choke conversion to buy?
- Pics of 455 ?
- 69 h/o
- why I haven't been on...
- 1968 Vista Cruiser slooowww build
- My 68 442 Convert Restoration
- '72 Cutlass Supreme Resto
- w30 oem tachometers
- 1956 Oldsmobile Rocket Engine Rebuild
- Body bushings
- 74 H/O mini resto
- 1970 Cutlass Supreme Convert
- Firewall Replacement
- quarter panel replacement
- 1974 Convert 88, are there resto parts books?
- Jimi2Much 67 442
- Exhaust Problem
- 71" 442 rebuild
- 1972 Cutlass Supreme
- 87 4 door cutlass supreme
- been in a barn since 1982, the story of the forgoten 70 olds
- '66 442 Disc Brakes
- '70 Cutlass Door Jamb Vents
- 64 Starfire Convertable.
- W-30 scoops
- 1967 442 decoding help
- 1968 442 Restore
- 70 Vista Firewall
- '73 Omega Hooker Headers Install
- 1969 442 Dash - assistance needed
- Any reason why this Master Cylinder wouldn't work
- 84olds
- my 64 F85
- 1968 Cutlass Supreme Overhaul, Drivetrain Edition
- 1967 Oldsmobile 442 Build
- Twin J racing's '71 Cutlass Project Thread
- 69' Resto begins
- 72 Blue 442 update
- '73 Delta
- 442 Remodel
- Rebuild Carb or Not?
- 1971 Cutlass Floor Replacement - PART 4
- 1971 Cutlass Floor Replacement - PART 3
- 1971 Cutlass Floor Replacement - PART 2
- 1971 Cutlass Floor Replacement - PART 1
- My 64 J88
- Munice M-21 Project
- Seeking Motivation 72 Cutlass Restoration...
- 350 engine rebuild advice
- Original Body Shop Ticket Located
- Remove & Replace Convertible Top Mechanism
- 1964 F85 V8 4 Door Deluxe
- Repop floors
- got my carb done!!
- The Rockets Trail - 1950 Olds 88
- powder coating vs por 15
- Thewoff/68 cutlass
- Are these OEM wiper arms 1955 Super 88
- 1972 convertible cutlass
- Progress Pics
- 1970 Vista Cruiser
- Wanting to post build as I go
- Brian's W30
- 1987 Cutlass Supreme Brougham Restortation
- 1970 Rallye project
- '64 Cutlass coupe resto
- Questions about 72 442
- Por 15 question & maybe a tip.
- SBO Stroker 380 assembly and details
- Tear Down
- omega man is back more to come
- 1969 Cutlass New engine, 4-speed, 12-bolt rear end
- Need advise on 68 442 conv
- Starting work on my 1971 Cutlass Supreme convertible
- 69 442 Frame off restoration
- Starfire too big for the garage?
- 70 442 convert. Front control arm options
- 69 Olds 442 Resto Mod (Project Bad Girlfriend)
- What to do w/1987 Cutlass Brougham 32k miles
- 350 head swap.
- 1972 Cutlass rebuild/upgrade
- Moroso evac setup
- 75 to 79 omega owners unite to help me
- 501Paratroopers 69 442 Build
- 64 Cutlass Slow build
- New HEI distributor
- Project Heirloom Olds
- 69 442 Conv Re-Build
- 1964 F-85 Deluxe Build
- 68 S (442) Steering Column Dash issues
- 1950 Olds Tudor Sedan project
- Convert to a stick
- 1970 442 Pace car?
- Firing up new engine, fuel question
- 1979 olds body sheet metal catalogue
- 70 w30 4 speed
- Date Codes Questions
- duh?????
- 70 Rallye 350 58k mile car
- 77 98 Regency 2 Door Coupe
- Is My Proportioning Valve Defective?
- 62 f 85 axle and suspension
- 1968 442 Convertible - Let's see how this goes
- The Restoration Lesson (MAW, Repeat)
- 64 D88 on overhaulin
- 67 Cutlass Supreme to 442 Clone project
- Paint scheme
- 79 Trans Am rebuild
- cutlass 442 1977 parts
- mondello intake
- SEMI-PRO TOURING 72 Cutlass 455
- 1962 f-85 cutlass daily driver
- 1969 442 Restoration
- Gauge restoration
- Number of Oldsmobile existing models??
- 1964 98 2 dr Coupe w/TH400 upgrade project
- My beautiful barn find is about to hit the road!
- 1969 Cutlass
- Will i ever
- when does a car become a clone
- Las Vegas Body Shop ??
- Thread on brake line union nuts. 1966 Toronado
- Need some help with my refresh!
- 1967 Cutlass Supreme Build
- 62 Starfire
- Floor replacing
- RE vamping the old girl
- 1966 Cutlass Project in Pa
- 1970 Pace Car Body Off - Plug or Bushing?
- 1966 Cutlass Holiday-A Resurrection-The Quest Bengins
- Welder-Sheet Metal, General Purpose
- Restoration of a 1970 442
- The twice totaled Cutlass, ressurected
- Firewall Insulation Pad
- 1963 Oldsmobile Starfire Coupe!
- Firewall insulation pad
- Gbody Restoration
- 71 custom cruiser tire jack and stowage decal needed
- Dealer Installed Options
- So it begins 71 Cutlass
- switch convertible top switch
- '66 442 - Finished and I drove it to....
- Restoration for a cause!
- 62 f-85 wagon
- Disc brake conversion issue w/power booster fitting
- 72 Cutlass convertible
- Pictures of my 442 .
- My '69 442 W30 Body Off!
- '66 88 from sask
- ebay 65 Cutlas
- Twenty year wait
- F85 1966 full restore
- Another 1973 Omega
- 73 nomega 455
- Fell Into My Lap - Documented 1970 W-30
- 1973 Olds 442 Header Panel
- 1962 Starfire
- 66 dynamic project
- Big, green, beautiful, and from 1960
- Swap question
- '66 442 Progress
