Recommendations on a cam size
Old Apr 30, 2017 | 01:09 AM
1968Cutlass_S's Avatar
Hello folks, I have a 1968 Oldsmobile Cutlass S with a stock 1969 Toronado 455. It has a few bolt on's in the form of a 750 Holley, Edelbrock torker intake, hedders, dual 2 1/2" flowmaster exhaust. The transmission is automatic and is built strong. I am tearing it apart to replace all the gaskets and I'm wondering if while I have the timing cover off if a camshaft swap would be good. I would be replacing the lifters and pushrods to match what I decide to go with. Cam sizing has always been something I should've studied more but didn't. My question is what duration size? Roller or hydraulic? I'm ok changing rockers if needed. I want it to be drivable with the family but add a little bump to it along with performance. Any ideas? Thanks in advance for your time. My name's Henry.
Old Apr 30, 2017 | 07:03 AM
oldsmobiledave's Avatar
Fyi
Questions that need answering
What gears in diff?
What rear tire size?
What converter?
How do you plan on using the car?
Answer all of these questions before choosing a cam if you want a balanced drivetrain.
Old Apr 30, 2017 | 09:47 AM
cutlassefi's Avatar
What gears in diff?
What converter?
Good questions.
OP - you can have a roller and it'll still be hyd. More changes would need to come with that however. Also what lifter size etc. You'll need to make a few decisions and observations before you can move forward.
76 Regency
Nov 11, 2014 05:44 AM
Oldsmaniac
Jun 20, 2014 05:44 AM
Uncle Hulka
Mar 12, 2014 03:41 PM
Ablast
Jun 15, 2013 05:50 PM
CheckM8t
May 2, 2007 08:11 AM
