71 Cutlass Body mount locations
I’m installing body mounts on a frame off restoration 71 442 hard top.it’s been awhile so I’m not sure where the rubber mounts go. The kit has three different ones. There are two which are slightly thinner with a smaller diameter through hole, there are four cushions . ( I believe two of the coshions go at the top of the rear cross member) and the rest are the same with a larger through hole. Does anyone have a diagram of the location, or a link to previous posts, it would be much appreciated
I am attaching a copy of the 71 body mount locations from the PIM. The quality is not that great but should help. The mount on the right in your picture should be the compression mount. The one on the left is a body mount Plug. I do not believe you use the mount in the center of your picture. What I don't see in your picture is the rebound mounts. Hope this helps.
