1970 442 4 Speed Restoration
Old Oct 20, 2016 | 10:33 AM
70_442's Avatar
Starting on the restoration/modification of my 70. This thread will probably not be for the purist on this site, I will be making some updates along the way (Brakes, suspension, transmission)
starting point, new Ride Tech suspension parts
Getting ride height set
prepping frame for powder coat
Old Oct 20, 2016 | 10:44 AM
gear head's Avatar
Haha, Love the old school folding tape measure...
Cool project, how far are you going to take it?
Old Oct 20, 2016 | 11:01 AM
70_442's Avatar
Plan now is:
Ride Tech front arms upper and lower
Ride Tech coil over on front and rear
Wilwood disc brakes front and rear
New fuel and brake lines
Energy suspension for body and rear arms
Legend 5-speed transmission
I have factory W-25 complete, W-30 Alum factory intake, W-35 factory wing.
Adding W31 cam to engine. Rest of engine bay will be restored to factory spec.
Minor restoration on select interior components
Strip and paint underside of body
Plan is to get it that far and back on the road. Complete body strip and paint will be phase II.
Old Oct 20, 2016 | 01:02 PM
RetroRanger's Avatar
72 Olds CS
Nice looks like a good project will look forward to updates.
Old Nov 10, 2016 | 08:36 AM
70_442's Avatar
Frame back from powder coat. Guy did an awesome job!
Old Dec 15, 2020 | 01:40 PM
70_442's Avatar
Things got crazy, I was taking it apart for some metal repair and decided not to stop.
Only bad spot in the floor!
Filled some misc. holes in the firewall that were added or not needed.
There were 23 holes under the dash.. Sigh
Hauled the car over to Indy Pro Strip where it went into a phosphorous acid tank. Paint, rust and undercoat gone!
Old Dec 15, 2020 | 04:31 PM
Loaded68W34's Avatar
The oversized wide oval tires are pretty cool. Where did you find them?
Old Dec 15, 2020 | 05:34 PM
postsedan's Avatar
Subscribed....Fun Project :-)
Dan
Old Dec 16, 2020 | 01:35 PM
70_442's Avatar
They are Firestone tires. TireStickers.com cut the letters out based on the original tires.
Old Dec 16, 2020 | 05:11 PM
dc2x4drvr's Avatar
Nice project,
Rocket On!
Old Dec 17, 2020 | 12:32 PM
442Dude's Avatar
Good afternoon. This looks like a fun project and similar to mine. I'm going resto mod and changing many of the same things to include the brakes, suspension, transmission, dakota digital cluster, adding fuel injection, and have also significantly upped the horsepower and torque from the engine. Here is the link to mine....this year is two years I've been working on it. I hope to be done next Spring depending on how many more delays I experience from COVID.
https://classicoldsmobile.com/forums...to-mod-148439/
Great job!
Old Dec 17, 2020 | 05:49 PM
70_442's Avatar
E-Coat
Thought I would add some pictures from Lippert Industries in Elkhart IN.
Old Dec 17, 2020 | 05:52 PM
70_442's Avatar
dc2x4drvr...I also have a LGT700 - 5 Speed still in the crate. How do you like yours? Any concerns you need to share with me?
Any info you can share about the ARH headers would be appreciated. I was going to go stock but Thorton is out of stock and have not read great reviews about other suppliers.
Old Dec 17, 2020 | 06:09 PM
scrappie's Avatar
What is that dip? Is that epoxy prime after or from dipping in something? Nice clean slate to start, Im tuned in.
Old Dec 17, 2020 | 06:25 PM
70_442's Avatar
It is e-coat primer. Car is dipped in multiple tanks then oven baked. Tank chart will be uploaded for your viewing pleasure.
Old Dec 17, 2020 | 06:54 PM
dc2x4drvr's Avatar
I love the LGT700, works fine with the original z bar, and Quick Time bell housing. The vendor modified the trans shifter so my original Hurst lever bolts to the trans without any modification. ARH, as I said several times are undoubtedly the best fitting headers for ‘70-72.period.
You sir are over the top on your body resto, I am subscribed!
BTW, let me know if you need info, on my trans shifter mod, I might be able to help.
Old Dec 18, 2020 | 02:48 AM
scrappie's Avatar
Wow! that is quite the process. What else do they dip in this process? Is it mostly auto restorations? It looks like what would be done to raw sheet metal body parts in a factory. What could someone expect to spend for that treatment if you dont mind me asking?
Old Dec 18, 2020 | 05:21 PM
70_442's Avatar
scrappie...For the body, two doors, two front fenders, trunk lid and complete radiator support was $2650.
Old Dec 18, 2020 | 05:29 PM
70_442's Avatar
scrappie...To answer your other questions, they dip a lot of trailer frames and parts. Elkhart is the trailer manufacturing capitol of the US. I also saw government Hummer parts and electric vehicle parts/frames.
I have worked in an auto plant paint line and their process is the same. The only difference is the orientation of the vehicle as it goes through the tank. You are correct in assuming the metal has to be clean and raw. My car had just left the Indy Pro Strip facility three hours prior to arriving at Lipperts.
Old Dec 18, 2020 | 05:31 PM
mrolds69's Avatar
It looks good! Tiny little shop though, huh?
Old Dec 18, 2020 | 06:21 PM
scrappie's Avatar
Thanks, impressive operation.
Old Dec 27, 2021 | 03:39 PM
70_442's Avatar
Finally got the body back on the frame. Still plenty to do...
Old Dec 27, 2021 | 03:47 PM
70_442's Avatar
Rear Spoiler
Most of the 50 years of abuse is fixed. Previous owner had used filler to blend in the spoiler risers to the spoiler. Still a little rough around the edges that will be addressed closer to paint time.
Old Dec 27, 2021 | 03:55 PM
70_442's Avatar
Body is painted and will be back on the frame for good soon.
Hood and spoiler have both come a long way.i
Ended up being a pretty good hood overall. Had it bead blasted and the damage is minimal. Looks like it took a shot to the nose at some time in it's life.
Previous life had a nut braised into a hole for the hood hinge mount.
New metal with a shoulder nut welded to the back side will clean things up.
The guy I bought this from said one of the owners had Chevelle style hood pins on this hood.
Probably going to cut this out. Would be nice if I could find a picture of a hood hole without the bracket to use for reference. I'll probably just center a hole with the fiberglass hole and make it just big enough to get the pin through.
Old Sep 19, 2025 | 01:14 PM
70_442's Avatar
It has been a long time coming, but the 442 is ready to come off of the lift. Hoping the next phase of the project (final assembly) goes as smooth as these projects can go.
Old Sep 19, 2025 | 02:20 PM
vCode442's Avatar
Vincit qui se vincit
9 years, that’s amazing. Looks good, excited to see it on the road!
442operator
Nov 9, 2023 05:29 PM
blackdog6124
Mar 10, 2017 05:43 AM
gasserdays
Suspension & Handling
15
Oct 29, 2012 10:27 AM
STAYBG
Mar 15, 2010 09:24 PM
Gert3116
Feb 23, 2008 08:27 PM
