Newbie tackling 65 Cutlass
Old October 2nd, 2017, 12:03 PM
llcooljc's Avatar
New here. I just inherited a 65 cutlass convertible that spent its entire life in Texas. It has been sitting in a garage for over 23 years unmoved. Almost no rust. The catch?? It was a hurricane Harvey victim. It was under water for about a week. (Rain, not salt). I have torn out the interior and am now getting to the motor. 330 high compression. It definitely will need a rebuild which I plan on undertaking myself. (Other than machining which I am not equipped to do.) anyways, are there any complete rebuild kits available? Or do I have to go piece meal? Any info would be appreciated. Thx John
llcooljc is offline
Old October 2nd, 2017, 12:14 PM
Welcome to the site. Nice project, hope you can dry it out and do some rust prevention. Egge machine sells kits. You might consider some mild performance parts instead.
oldcutlass is offline
Old October 2nd, 2017, 12:18 PM
stan 65 cutlass's Avatar
looks like a solid one, good luck
stan 65 cutlass is offline
Old October 2nd, 2017, 03:26 PM
classicmuscle442's Avatar
Welcome to C O, very nice looking Cutlass, I could make room for it but I might have to sleep in it. Just a thought, not sure how high water got but may want to drain rear end.
classicmuscle442 is offline
Old October 2nd, 2017, 03:52 PM
Olds Fever
CRUZN 66's Avatar
Welcome to the group... Looks like a good project... Do you know the actual depth of water it was in???
CRUZN 66 is offline
Old October 2nd, 2017, 06:30 PM
llcooljc's Avatar
I’m not sure, but what I do know is, the motor was full of water. The tranny fluid on the other hand looks unaffected.
So im assuming higher than carb...lower than Tran dipstick tube.
llcooljc is offline
Old October 2nd, 2017, 06:37 PM
lemoldsnut's Avatar
welcome to the site
Some great folks here with good info.
I have two 65 parts cars if you need some things
supercarsunlimited.com is a great source for mechanical parts.,
Larry
lemoldsnut is offline
Old October 3rd, 2017, 09:31 AM
llcooljc's Avatar
After pulling the oil plug, about 3-4 gallons of water flowed out. Then this...
llcooljc is offline
Old October 3rd, 2017, 09:33 AM
lemoldsnut's Avatar
Time to tear it done and inspect.
Old October 3rd, 2017, 09:49 AM
m371961's Avatar
Welcome. I would pull plugs, start flooding cylinders with WD or trans fluid and keep turning it by hand, until you pull it. Drain and clean rear. See how much water got where, including wheel bearings. Get it dry asap before rust sets in. At least it is fresh water.
Like asked above, how high did the water get?
m371961 is offline
Old October 3rd, 2017, 02:44 PM
OLDSter Ralph's Avatar
Welcome. Enjoy the project, it will be worth it. Wheel bearings, brake wheel cylinders, rear axle, fuel tank and electrical connectors are also things to check. The people on here are very helpful and knowledgeable. Good luck
RALPH
OLDSter Ralph is offline
Old October 3rd, 2017, 03:10 PM
Water is heavier than oil so it will be on the bottom. The brown mess is oil mixed with water. You can try doing an oil change and mechanically prime the engine without starting to flush it out. Then drain, add fresh oil, a new filter, and start it. You have nothing to lose.
Old October 3rd, 2017, 03:44 PM
therobski's Avatar
X2 OldCutlass good idea,
therobski is offline
Old November 26th, 2017, 11:23 PM
Gerald Nickels's Avatar
Me I would of left my driver there and drove the 65 out of harms way. Just me. At least the out side is good.
Gerald Nickels is offline
68Cut
May 20th, 2017 09:14 AM
z11375ss
November 19th, 2014 08:38 AM
usertroy
December 13th, 2012 08:19 PM
Scottem
May 29th, 2012 11:24 AM
marty
Site Help
November 30th, 2009 06:08 PM
Quick Reply: Newbie tackling 65 Cutlass
