PDA
View Full Version : Paint
Pages : 1 2 [3] 4
  1. Air Cleaner Color for 1969 442
  2. Color research
  3. 66 Cutlass Midnight Rider
  4. Clear Coat Options
  5. 77 Olds Toronado Engine paint
  6. air cleaner paint
  7. Blue engine paint
  8. stainless trim removal
  9. Prime the bead area on SSIII's?
  10. Hood Hinges
  11. "Plasti-Dip" the roof on my Two-Tone Cutlass
  12. Kicker panel color. Any ideas?
  13. What color is this?
  14. Inner Fender Resto
  15. 68 442...Bad Stripes
  16. Dupli-Color MOTIP Gold Wheel Paint ????
  17. Paint for a 1970 Oldsmobile cutlass' grilles
  18. 70 blue interior colors
  19. Restoration Paints
  20. 68 fender stripe
  21. Color Combo Options 69 442
  22. Never seen this color combo.
  23. 1981 Color Code 69 Dark Sandstone Metallic
  24. fender stripes
  25. 71 cutlass conv
  26. engine paint
  27. Paint time, where do I get it done
  28. Correct supreme grill color
  29. Fish eye! any paint guys?
  30. Looking for Reputable paint shops in HI or FLA
  31. painting instructions
  32. I've seen some bad paint mismatches, but this takes the cake...
  33. 68-69 455 engine red color name or code
  34. Pin Stripe Specification for 1970 Cutlass SX Convertible
  35. Touch up paint won't buff out the same as original
  36. paint wheel
  37. W25 hood stripes
  38. paint code
  39. setting blocks
  40. First shot of color
  41. Upper Dash color
  42. Best primer/paint for frame
  43. Powder Coating Engine Block
  44. Comments on this PAINT COMBINATION
  45. Core Support Stone Shield Color
  46. Chrome Plating Kits
  47. Correct color for transmission crossmember?
  48. Dash mark for paint code ( - )
  49. Temporary protection
  50. 71 72 Saturn Gold Code 53 Issues
  51. Orange Peel Hell
  52. Paint shop referrals- Boston suburbs
  53. Paint ID
  54. paint remover
  55. 1975 Hurst/Olds air cleaner lid paint: gloss, semi-gloss, satin?
  56. want to paint some underhood parts
  57. metal portion of dash...what color ?
  58. Paint shops in the 209???
  59. bare metal on suspension
  60. 67 cutlass bumper filler color
  61. 69 442 Dash resto help needed
  62. Tony's Bamboo DIY Paintjob
  63. ppg omni paint for code 28 twilight blue
  64. Tail light bezels
  65. what color?
  66. Suggestions Needed
  67. 65 Delta Crazy Talk
  68. 1969 442 stripes
  69. PPG or BASF
  70. '70 442 Stripe Question
  71. Hate it or Love it 71 Supreme
  72. Anyone have pics of black 70 71 72 "s"
  73. 1968 442 color paint for headlight housing
  74. Rough hood - wetsand or not?
  75. Need some advice on engine compartment
  76. How I spent my day, junk in the trunk
  77. Lower 1987 442 Color
  78. SS1 black?
  79. Anyone hear of "SPI" paint before?
  80. 1972 442 hood stripes
  81. cowl tag help
  82. Fresh paint
  83. Long lost wax
  84. 71 Conv. Trunk stripes
  85. OEM Engine & Transmission Paint Color For 1948 Deluxe 66 With Hydromatic
  86. 1967 Paint
  87. did some painting
  88. Proper Paint Mixing
  89. Cost of a proper paint job
  90. crazy paint scheme 1956 Super 88
  91. 67 422 rockers panels
  92. info and opinion wanted
  93. 75th Anniversary Olds Regency Special Paint?!
  94. 1969 supreme lower body paint
  95. Underbody of 72 cutlass
  96. 1978 cutlass supreme paint codes
  97. Engine Paint Colors: The Definitive Solution - Let's Start a Library!
  98. 1957 Two Tone
  99. jade green
  100. Respirator for Small Priming/Paint Projects
  101. 1969 trophy blue
  102. Paint Sources
  103. Is there an "official black" to use?
  104. Lacquer paint
  105. What color is this? Toronado 1970
  106. Gloss Black from Bamboo Yellow
  107. 70 Blue stripe cars?
  108. Paint Supplier help
  109. Oldsmobile Blues 1970-72
  110. Colour name/code?
  111. Painting a car original color
  112. 70' 442 / 455 engine paint
  113. What Color ???
  114. Paint Code?
  115. Paint code for 70 442 black?
  116. Underhood Paint, any suggestions?
  117. Hood strips
  118. Metal Flake Paint
  119. Trim Tag Convertible Top Code
  120. antique briar exterior color
  121. 1988 Cutlass GT #185
  122. restoring my dash and console
  123. painting calipers question
  124. Opinion On Color Scheme
  125. Color suggestions?
  126. Restoring Oxidized Paint
  127. Paint job thread, '67 Delta 88
  128. Jack Assembly Paint
  129. 71 Sable brown, code 68
  130. will my compressor keep up when spraying
  131. filler over etch or etch over filler ?
  132. engine painting
  133. 68 super stock 2 wheel paint as original
  134. Tahitian turquoise
  135. painting over lac
  136. 13 years later
  137. Brass-look paint?
  138. need pinstriper near layfayette in
  139. Blue paint for the 1962 394 motor?
  140. 72 W-29 Stripe Location - Does This "Look" Right?
  141. Nassau Blue 69 Cutlass Supreme Convertible
  142. Painting tail light bezels w/ caliper paint
  143. HELP: I need a mixing formula for Nassau Blue
  144. what color????????
  145. How do you buff out a filled deep scratch?
  146. OEM Paint Codes
  147. 1967 442 Pin Stripe
  148. 69 Gold interior paint
  149. Painting all the little things
  150. Opinions Wanted - Non Stock Paint Colors
  151. Header paint
  152. phosphoric acid rust removal
  153. Cost of paint/reducer/hardner etc...
  154. DuPont 69 H/O Firefrost Gold base/clear no more.
  155. very very new to bc/cc
  156. SSIII Painting suggestions
  157. Purists will hate it, but....
  158. 68 Delta 88 paint code
  159. aluminum valve cover paint/prep
  160. Where to put the stripe?
  161. To Etch or not to Etch
  162. sand a base coat?
  163. colors
  164. upper control arm shaft
  165. Repairing my old paint job.
  166. '72 Cutlass convertible - color suggestions please
  167. Anyone have pictures of a Burnished Gold 70 442?
  168. What color is this?
  169. 1966 442 Front Fender Rockets
  170. Bitttersweet or Kashmir Copper
  171. dash
  172. Trunk paint advise
  173. 1971 Cutlass/442 colors
  174. Factory stripes ?
  175. Cleaning up old Rims
  176. Painting on rechromed moldings
  177. paint code
  178. Where is the Link to Detailing/Paint colors?
  179. Interior paint help please !
  180. What Color should I paint my 67 442?
  181. Doubonnet? (sp)
  182. Primer process?
  183. Stencil Kit?
  184. Code 43
  185. serious question
  186. Toughest paint
  187. Paint Color for sheet metal 'under' car?
  188. House of Kolor, anyone buy from them recently?
  189. need paint ideas
  190. Core Support, bumper brackets, trans crossmember correct paint
  191. body stripes
  192. Get a load of this paint job
  193. '70 442 Underhood / Chassis Colors
  194. 54 Super 88 Tutone paint
  195. Requesting pictures of Cranberry Metallic
  196. argent grey rallye wheel powder coating
  197. Thinking Outside the Box on Color
  198. Trunk Spatter Paint for 67?
  199. question about spray painting headers...
  200. Cleaning/Coating/Painting Parking Brake ASM
  201. Good source for touch up paint
  202. Paint in a rattle/spray can
  203. Comparison shopping spray engine paint
  204. Under body paint?
  205. How Should I Finish My Paint Job
  206. Correct trunk latch and lock retainer color?
  207. 1968 Cutlass Radiator Color Gloss
  208. Nugget Gold Questions
  209. Whats your trunk look like ?
  210. 1963 F85 Cutlass
  211. 1975 "Sunfire Orange" Delta 88
  212. What paint colour is this?
  213. 66 442 bucket seat back paint
  214. duplicolor high heat/vht product line high heat aluminum
  215. Photoshop my Car?
  216. Grill Paint
  217. Top frame color
  218. Fender color 71 442
  219. Paint Manufacture
  220. My 442 is finnaly in her dressing room
  221. '70 442 Anti-Sway Bar's Color
  222. Core Support
  223. where to get olds gold in spray cans
  224. 70-72 Trunk & 1/4 W-30 Stripe Example
  225. Which do you prefer ?
  226. vin code
  227. Kashmir Copper or not?
  228. How do I fix this paint problem?
  229. Paint code?
  230. Painted Stripes vs. Decals - 70 442 Convertible
  231. 70 442 Convertible Dash and Steering Column Paint
  232. Anyone buy paint from here?
  233. Underhood Paint - Heat requirements?
  234. Hot Rod Flatz question
  235. 1972 442 Antique Pewter Poly Paint Code 14
  236. Cut and Polish
  237. Gas Tank Paint
  238. Anybody used.....
  239. color under hood vents
  240. Hood stripes only?
  241. Sandpaper
  242. Paint code 81
  243. 70 Inner Headlight Buckets
  244. paint question
  245. Looking for a High Quality Body/paint shop in the Seattle area
  246. Factory Body Finishing Process
  247. help
  248. grill paint
  249. Messed with the Cutlass hood
  250. Interior paint/dye - "off the shelf" gold recommendations?
