Grill Paint
Old December 30th, 2011, 02:39 PM
501Paratrooper's Avatar
Grill Paint
I searched for the correct color for my 69 442 grill paing, I found Krylon Dull Aluminum for the silver part what about the black?
Semi Gloss black from some pictures I've seen but on ROP I saw Flat Black.
Also I saw a thread on repairing the plastic tabs, anyone have any other suggestions?
Thanks!
501Paratrooper is offline
Old January 2nd, 2012, 06:34 PM
Anyone?
I fixed my tabs with a plastic repair kit from NAPA, worked good I filled some cracks with BONDO and it worked pretty good as well.
I have discovered the Krylon Dull Aluminum is hard to find but still shows on the internet. Anyone have any suggestions on the black? Semi gloss or Flat?
Old January 2nd, 2012, 06:55 PM
70Post's Avatar
Use a Semi Flat Black (such as Krylon Semi Flat Black) or possibly a Satin Black. Flat is TOO flat and Semigloss's are too glossy IMO.
70Post is offline
Old January 2nd, 2012, 07:14 PM
70Post, Thanks!!!
Old January 3rd, 2012, 05:02 AM
Rocketbrian's Avatar
I had a small missing section of my 442 grille and used a piece of that plastic that almost everything is packaged in today as a backer and glued it with plastic epoxy. Once hardened I finshed off with body fill and / or spot putty as a final finish. Turns out great. The dull aluminum by Krylon is now under their "Metallics" line - part # 41403. The semi-flat by Krylon is defintely the way to go. I can't find the regular SF locally, only the "Rust Tough" SF, part #49203, but it is still the same sheen.
Rocketbrian is offline
Old January 27th, 2012, 08:15 PM
Here they are before and after, thanks for the help!
Old January 28th, 2012, 04:20 AM
They look great, what a difference. It's always good to have before and after pictures to look back on.
Old January 28th, 2012, 07:58 AM
Thanks!
Old January 30th, 2012, 07:51 AM
72 Olds CS
RetroRanger's Avatar
thanks for the post para...I just got some of the 1403 dull aluminum for my tailights a test spray showed a very acceptable color match to the original and a perfect sheen. Even my wife (who by all standards is hard to impress with car parts) was impressed
BTW ordered the 1403 on Amazon and the order was fulfilled by the local hardware store (doh)
RetroRanger is offline
Old January 30th, 2012, 09:10 AM
71 sienna supreme's Avatar
ACE Hardware Stores have the Krylon Dull Aluminum 1403 & Satim Black on their shelf. If not they can order it.
71 sienna supreme is offline
Old January 30th, 2012, 07:28 PM
Old School Olds
tru-blue 442's Avatar
Nice Job! Looks great.
tru-blue 442 is offline
Old January 30th, 2012, 07:32 PM
Thanks to all, I found it at Ace too.
Old January 31st, 2012, 04:48 PM
navvet's Avatar
I had a serious issue with the grille of my 64 olds 88. I took the car for a quick oil change
last spring. The tech also decided to check my tranny fluid. When he did he walked to the front of the car and dripped the fluid from the dip stick onto the dull aluminum paint on the grille and left spots. The spots came out looking like bright chrome. There must have been @ 20 spots and it looked stupid sooooo I proceeded to rub the entire grille area and wow it looks great.
I would not suggest everyone try it. I had no choice aside from repainting the grill and I wasn't in the mood for such detailed painting.
navvet is offline
Old January 31st, 2012, 07:13 PM
stlbluesbrother's Avatar
Instead of creating a new thread in regard to grilles and paint, I'm piggybacking off this one (now that the orignal post has been answered).
My question: did 1970 NOS Cutlass Supreme grilles come with silver paint on them?
stlbluesbrother is offline
Old January 31st, 2012, 09:03 PM
70Post's Avatar
They SHOULD have the silver paint on them (with some black accented areas) but being NOS you "never say never".....can't discount the chance of a set of unpainted "reject" grilles being put into the NOS inventory.
70Post is offline
Old January 31st, 2012, 09:24 PM
Great - thanks for the reply.
Have you seen sets with these blemishes along outer edge (nearest the headlamp housings)? They're almost like blisters in the plastic.
I checked the grilles on my gold car and sure enough, it had them, too.
Old February 2nd, 2012, 02:36 PM
bump to see if any takers. Check out the pic
Old January 27th, 2014, 05:04 PM
jensenracing77's Avatar
Does anyone have a side by side comparison with a nice factory grill and one painted with the dull aluminum? I can't find the paint. I may have to order it on the net.
jensenracing77 is offline
Old January 27th, 2014, 05:34 PM
72 Olds CS
I dont have a nice factory grill but I have a crappy before after w some 72 tailights this is using the krylon dull aluminum. it has a very nice sheen unlike most silver paints that look like well silver paint !
Old January 27th, 2014, 05:40 PM
Looks great. Thanks
Old February 7th, 2014, 03:54 AM
DLaz70OLDS98's Avatar
Retro the tail lights look great. After you painted them with the dull aluminum did you put any type of top coat on. I am wondering what type of durability the Krylon has.
DLaz70OLDS98 is offline
Old February 7th, 2014, 05:32 AM
72 Olds CS
Thanks for the props guys.
I didn't use any top coat on them, but I too wondered about the durability as it is an interior rated paint. So far no issues, it's only been about2 years 2500 miles. My car isn't a daily driver, it spends it's off time in the garage and to be honest the harshest treatment those tai lights see is an occasional washing. So all that said I would do them again w the dull aluminum paint.
A grill may be tougher on the paint as they could see road debris, bugs etc and need more scrubbing to clean. I plan to do some grill work is summer so I will find that out as well.
Old February 7th, 2014, 08:42 AM
If one were to put a top coat on what would be a good top coat????
Old February 7th, 2014, 10:03 AM
72 Olds CS
I don't know. A clear May yellow w uv exposure, I cleared some back up lamp housings I redid and the satin clear had a little to much gloss in it for my tastes, but I did it to keep the brass socket from oxidizing so it still serves that purpose and it isn't really easily visible.
Old April 23rd, 2014, 03:43 PM
Sammy70 455 Supreme
sammy's Avatar
Just wondering if this is the correct grill paint.....?
sammy is offline
Old April 23rd, 2014, 04:55 PM
I'm sure it is, new label compared to the one I got over a year ago but still has the part#41403.
Old April 23rd, 2014, 06:10 PM
72 Olds CS
X2 the label is different but the 1403 number is there
heres a link to the
amazon version amazon version
similar label
Old April 23rd, 2014, 06:20 PM
Sammy70 455 Supreme
sammy's Avatar
Thanks for confirming this....
Finally found some at my local hardware store too...I cleaned them out of their stock
sammy is offline
Old April 23rd, 2014, 06:27 PM
I got a can of the the 1403 from amazon and when I got it i read that it is interior paint. I found that motorcitysupercars on ebay sells a Grill, headlight and A rally wheel paint that is an exact match. I used it to paint the grill insert on my 67 cutlass and was more than happy with the final product. I am away on business but will snap a few pictures of the final product and post if interested. I feel that this paint is more durable then the 1403 since it is an interior paint, but the is just my opinion.
Old April 23rd, 2014, 08:08 PM
72 Olds CS
yes post pics please
Old April 23rd, 2014, 11:32 PM
  #31
No problem Retro. I will try to get some up tomorrow night or Saturday. I will also take pictures of both paint samples next to each other for comparison. They were almost identical. Again I went with the detail paint thinking it would be more durable.
Old April 27th, 2014, 05:06 PM
  #32
Sorry for the delay in posting these pictures. The first two show the grill insert all painted with the detail paint I purchased from Motor City. The third shot is the grill insert with a piece of card board that I painted right half with the detail paint and the left half is the Krylon 1403. They are almost identical in appearance. Here is a link to the detail paint on ebay: http://www.ebay.com/itm/1964-77-GM-G...a8cef4&vxp=mtr
Old April 27th, 2014, 05:32 PM
  #33
Looks nice!
Old April 27th, 2014, 06:05 PM
  #34
Thanks. I am very happy with how it turned out.
Old July 8th, 2014, 03:08 PM
  #35
firefrost gold's Avatar
How did you guys prep them looking at touching up a Rallye 350 grill set one is oem stock other a cutlass that i got to replace the broke one . sand with what grit ? clean with ? Thanks
firefrost gold is offline
Old July 8th, 2014, 04:18 PM
  #36
72 Olds CS
my only prep was to clean thoroughly
Grumpy
January 8th, 2020 02:40 AM
O-dawg
August 22nd, 2015 05:27 PM
booois
August 19th, 2014 06:39 PM
CLcutlass
Paint
October 2nd, 2011 04:49 PM
jims2000lt
June 8th, 2010 06:30 AM
Quick Reply: Grill Paint
