colors
Old May 10, 2012 | 10:06 AM
occph's Avatar
colors
How can I find the originals colors for the engine compartment? Like the engine, exhaust. Air cleaner, radiator, and power brake pump for a 68 Cutlass S Convertible?
Old May 10, 2012 | 01:37 PM
Indy_68_S's Avatar
Engine = Olds gold
Exhaust Manifolds = Dark cast gray
Air Cleaner = Red for 4bbl / Black for 2 bbl
Radiator = Semi gloss black
Power Brake Pump ? Do you mean booster ? My '68's was dark grayish/silver plated, but some claim other '68s were gold cad plated.
If you're looking for exact colors In the proper gloss/flat, hopefully some others will chime in...
Old May 10, 2012 | 02:48 PM
rcorrigan5's Avatar
Randy C.
These various paints are available from a multitude of Olds parts suppliers, such as Fusick, Supercarsunlimited and Year One. The red for the 4bbl air cleaner is a unique red so you would want to go to an Olds parts supplier. A lot of the parts are simply GM chassis black - a color that is available at several car parts stores. For exhaust manifolds, I bead blasted mine and then used a high heat cast blast paint. It's been on there for 5 years and a little over 1800 miles and it still looks pretty good. I painted my fan semi-gloss black. There are some other glossy black pieces (breather tube from exhaust manifold to air cleaner, cover of voltage regulator come to mind) under the hood as well. With regards to the hood hinges, I cleaned and painted the hinges a cast iron color. I also bead blasted the hinge springs and painted them a stainless steel color and they look real good.
As well, if you've got other Olds enthusiasts in your area, I suggest talking with them for their input and then use that input for your application.
I wanted mine to be as close to original in appearance as I could get it.
Randy C.
Old May 10, 2012 | 08:45 PM
jdana24's Avatar
1968 Olds Cutlass S
I've researched this extensively and have found a number of sources and they don't always match up with each other. Listed below is information which was sent to me by a contact who was restoring his A Body car:
GM A-Body Paint/Plating Information
All of the General Motors engine compartments are very similar. Each division may have made small changes to suit their individual applications, and each have their own engine colors, but the major components color of parts, and plating that are used remain essentially the same. I would emphasize that research is the key. When you take your engine out for rebuilding or detailing, photograph the components before they are disassembled. Remove the parts and note whether they are plated, painted, or just natural. When the car is being reassembled the parts should be returned to their original condition. Through research it's been discovered that the following components should be restored as shown. Naturally there are always exceptions for a given year but these can be used as a guideline.
Accelerator rod, accelerator lever:
Black oxide.
Alternator:
Natural aluminum finish, no paint or plating.
Alternator fan:
Zinc plated (silver).
Alternator pulley:
Silver cad plated or gold cad plated (depending upon the application). Most plating shops can handle either application.
Battery box hold down clamp:
Semi-gloss black.
Brake distribution bracket:
Cadmium dichromate.
Brake lines:
Natural steel, no paint or plating.
Brake line clips:
We've seen these clips in natural finish, black oxide, and zinc chromate (green) finish.
Clutch cross shaft:
Gray phosphate plate.
Clutch linkage parts:
Gloss black finish.
Clutch fork:
Natural steel finishes that can be painted with cast-iron spray paint.
Clutch return spring:
Natural steel or gray phosphate.
Clutch return spring bracket:
Natural steel finish.
Control arm cross shafts:
Semi-gloss black enamel.
Control arm bolts and large-end washers:
Natural steel.
Control arm adjustment shims:
Natural steel.
Engine accessory braided ground strap:
Natural, no paint or plating.
Engine dipstick handle:
Exhaust manifolds:
This is another area where the GM divisions differed. According to restoration sources, Chevrolet exhaust manifolds were over-sprayed when the engine was painted. According to Pontiac sources, Pontiac engines were painted first, then the exhaust manifolds was installed. Whatever the case may be, if you are going to drive the car, any over- spray that may be sprayed on the exhaust manifolds will bum off quickly.
Exhaust manifold locks:
The exhaust manifold locks were natural finish unless the exhaust manifolds were painted; then they were over-sprayed.
Fan blades:
Fans on GM cars differed from brand to brand. Some divisions, like Chevy, painted the fan and blades black, while other GM divisions used natural stainless fan blades with black center hubs. If the fan was a clutch-type, the clutch was natural aluminum with a gold cadmium center. The clutch shaft and spring are natural finish.
Fender bolts, fender bolt washers:
Black oxide.
Frame or sub frame:
The frame and sub frame on all Sixties through Seventies GM muscle cars were painted semi-gloss black. Some restorers like the frames a little more on the shiny side, while others like a flatter finish. There are a lot of different formulas for this and different paints you can use. Most restorers use acrylic enamel or acrylic urethane finishes with a flattening agent for frame components because of their durability, One formula that you can use is as follows:
3 qt. PPG Delstar mixing black
1 qt. flattening agent
PPG DTR601 quick-dry reducer
Front springs:
Natural metal.
Fuel lines:
Natural steel finish, no paint or plating,
Heater/heater shroud:
Semi-gloss to gloss black lacquer. Generally, more shine than the engine compartment.
Hood hinges, hood latch, hood catch, hood springs:
These components look like they are natural finish, but they were actually gray phosphate plated. This process is available from several plating companies. Upper and lower alternator brackets: Most pulleys and brackets used on GM cars were painted semi-gloss black, but there are some exceptions to the rule. Research your particular car because on some GM brands, individual pulleys could have also been gray phosphates, zinc, or cad plated. Some of the GM divisions also used large aluminum brackets that were natural aluminum in color.
Horns:
Gloss black finish.
Horn relay:
Natural, no paint.
Ignition wire dividers:
Black plastic.
Inner fenders, firewall, radiator support:
As with the frame, there are many different formulas that can be used to achieve a semi gloss black paint to match the factory finish. Some restorers like to mix their own paint to get the shine they desire, but. many restorers also use a premixed PPG paint for their engine compartment. We have used PPG 9423 lacquer on our cars and it is about as close as you can get to the factory finish, We usually buy it in quart cans because that's enough to do a complete engine compartment. Many of the spray can manufacturers (e.g. Krylon, VHT) make a semi-gloss black that also looks good on engine compartment components if you don't have professional spray painting equipment. If you have spray equipment here's another custom lacquer formula that you can use:
2 qt. PPG mixing black #386
1 qt. universal flattening agent
1 qt. mixing clear #3 10
PPG DTL16 thinner
Master cylinder:
Most of the GM cars came with natural finish master cylinders. For a lasting natural look, they can be painted with cast-iron gray paint, which is available from a variety of sources such as The Eastwood Company, VHT, and Krylon.
Master cylinder lid:
The master cylinder lid should be cadmium dichromate (gold rainbow cad This type of plating is available from several sources. The master cylinder bail clips are natural metal.
PCV- hose clips:
Black oxide.
Power brake booster:
All GM power brake boosters were cadmium dichromate. The two companies mentioned above can rebuild and re-plate your power-booster.
Power brake hose clips:
Black oxide.
Power steering pump:
Gloss black enamel.
Power steering brackets:
Semi-gloss black enamel. Some brackets may actually look like a cross between semi-gloss and gloss black.
Radiator:
All GM cars of this era had Harrison radiators that were painted gloss black.
Radiator cap:
Radiator caps were not painted, they were plated.
Radiator shroud:
Radiator shrouds should be left natural plastic. Some shrouds on early GM cars were steel and they should be painted semi-gloss to gloss black.
Shock absorbers:
Gloss gray enamel.
Steering box:
The cast-iron portion of the box is natural finish. The access lid is natural aluminum; the bolts are black oxide.
Stabilizer bar:
Depending upon the GM division, these can be natural or semi-gloss black.
Stabilizer bar brackets:
Depending upon the GM division and supplier, the brackets can be semi-gloss black or natural.
Tie rods, steering components:
Natural steel finish. These components can be painted with clear or cast-iron colored paint.
Voltage regulator cover:
Gloss-black enamel.
Water pump pulley, crankshaft pulley:
Semi-gloss black, some crank pulleys were cast and left natural finish. Some water pump pulleys on early GM muscle cars were zinc plated.
Windshield wiper motor:
Gloss black finish.
Old May 14, 2012 | 07:00 AM
occph's Avatar
thank you everyone for your help
Olds luvr
Mar 17, 2010 06:57 PM
67442inmontana
Mar 11, 2008 08:55 PM
KQQLCAT
Oct 31, 2007 07:08 PM
mp71conv
Sep 14, 2007 10:27 PM
Sagern
Aug 26, 2006 01:35 PM
