View Full Version : Paint
- Fresh wet sand and buff
- Eastwood's new tool and garage painting
- 1965 Dynamic colours.
- Question on Underbody Color on Cutlass / 442 Assembled in Framingham
- touch up paint
- 1970 w30 gold stripe color-23197- G H
- Super stock II wheel color
- Paint inside of doors?
- Paints: black sheen
- Spray can primer or not
- Best place for body paint in Michigan.
- Color Recemendation for Headlight Housing
- Need the Correct, matador red Color .for 1970 Cutlass Supreme convertible
- Painting 72 cutlass bezels
- where to get 1966 f85 colour
- Cinnamon Bronze on 70 442?
- Nailing down Crimson Red
- Painting over POR-15
- 1969 442 grille and headlights surround silver
- '71-2 Cutlass W29 hood question - any mount differences?
- thoughts on flat-black color for 72 Cutlass louvre hood?
- aluminum parts paint preparation
- Olds engine paint
- 1991 "88" Bumper and molding paint code
- Eastwood's Mulsanne Blue paint
- 67 Delmont wHot Rod Black On Bottom
- Epoxy Primer
- Rally red paint 1970 code 73
- Another 1970 W-30 hood stripe question
- Anyone good at photoshop..?
- Color?
- Dash Color - 1969 Cutlass
- AAAAGH! Rain killed my clearcoat!!
- 71 Bittersweet Olds owners-need your help!!!!!
- Paint damage
- 71 CS convertible, wide hood/trunk stripe decals?
- 66 Cutlass headlight bezels
- Black Bottom??
- 66 bucket seat paint on metal parts
- Eastwood Paint?
- 72 CS tail lights, head lights and grill - painted black
- 1971 442 Striping Options
- Peaches n' Cream color?
- Viking blue
- 1971 cutlass supreme Viking Blue
- Petina Paint Job?
- Rust encapsulator vs. rust converter
- Silver trim
- the 70-71 442 orange color
- Which shade paint
- Paint for 1970 front Grills
- Paint between the roof frame
- No paint code on cowl tag
- Engine Compartment Paint Color
- Primer????
- Dash Paint ?
- Engine paint
- 1969 442 w32
- Should I clearcoat
- Aspen Green seller?
- Paint on aluminum
- Repainting 66 425 brackets?
- What Paint Code is Black for '72 Cutlass and How Can the Car be Titled
- Help with paint codes, 70 Cutlass & 71 Cutlass
- '85 442 paint codes
- Valve covers and air cleaner colors
- How Do I Find Out The Original Colour
- Help Needed to Decode 1970 442
- Olds 394 Red engine color code
- Help decode paint on 72 Cutlass
- Paint Question, 1970 442 Matching Number Car, Original Color Aspen Green
- 1955 olds paint
- What's your favorite white paint?
- 1970 442 W-30 Gold Stripes
- Quick rattle can question
- Anyone done their own Zinc plating
- Paint It, Black
- 1969 cutlass supreme color
- 68 and 69 SSII paint
- Paint color Grille
- If you needed paint
- 1971 442 firewall and cowl paint.
- Splatter paint?
- hood pad glue
- 1968 Red formula question
- Paint color for 1968 cutlass headlight housing
- dplf40 primer or is there better?
- interior paint for metal parts, console etc
- Engine paint
- Removing vinyl top remnants
- Painting over old primer?
- 1970 Green special order paint
- 1966 paint color chart
- Dark Saddle Interior Paint
- Interior Trim Color Questions
- paint color code
- soft edge masking
- Scratch help
- '69 fender (inside) color
- 72 cutlass paint question
- 1972 442 Striping with Non AOI hood
- Matching original paint on a 1957 88
- To epoxy or not to epoxy
- Should I attempt priming and painting myself?
- 69 442 Trophy Blue Paint
- 69 W42 paint stripe help needed
- Peeled paint
- Best Rattle-Can Pain for Bumper-to-License Plate Filler?
- Paint colors for '69 air deflector
- green and black stripes w-30
- bronze engine paint
- 66 fender scoops
- Interior coating/painting
- 1964 Cutlass fender extension paint color
- Paint color name
- Minneasota reputable paint shop
- Matching 15 year old paint
- 68 442 fender stripe colour code?
- paint color and code number
- top
- Masking teqnique on trunk / tail light trim
- 69 Trunk prep and primer and paint
- Sheen or color number of Frame and Firewall
- Why is my duplicolor grainy?
- Control Arm Refinishing
- Vinyl top delete
- paint stencil kit w30
- 71 442 stripe location
- what color is this car
- 68 Lower Dash Paint Color Code
- What paint should I use to clean these up?
- olds gold engine paint
- Identifying Color Code from a Movie 442
- Painting the door
- Liquid aluminum paint?
- Curiosity Question on Original Paint Process
- Paint or Convertible top first?
- 1971 Mopar Dark Metallic Gold
- Post Coupe Doors
- Urethane Primer Question
- 72 notchback
- Paint for trunk trim of 68 442
- 1955 Olds, Polar White - 60 and Panama Blue 41
- Painting brackets, core support - best method
- Need a Paint Code for 72 Cutlass OAI Hood Stripe
- 68 Cutlass dark green
- What color is this?
- Red paint under factory primer?
- Vinyl wood grain replace olds wagon
- 1972 Cutlass Supreme Hood Paint Scheme
- matching original paint
- Is this Monarch Blue
- What goes with a red interior?
- 68 tailight housing restore.
- Paint code 48
- PPG DP90 primer question
- 1969 442 paint help needed
- Nugget Gold Paint
- Gold Powder Coat
- 67 67 442 headlight bezel paint
- Paint color?
- nason paint line.
- Vinyl top paint
- do u need original paint
- The Day Is Here!!!!
- Should i paint my Delta like this?
- 65 442 single racing stripe vinyl/decal?
- Question about stripes on 70-72 OAI hood
- 65 Cutlass Sterling Mist with Black Roof
- Respirators
- 72 Cutlass needs a paint job
- 1968 Cutlass Convert. Resto
- Have you used Sherwin Williams paint?
- Por 15?
- Chemical Strip??
- roller coaster!
- White paint
- Frame Paint
- What color should I paint this Cutlass?
- Interior Paint Codes for 1966 442 Red Interior
- Post Blasted Body Primer Advice Needed
- Twilight Blue paint suppliers and other paint questions
- Rattle Can Advice Needed
- Engine color
- Matching 1973 Acrylics
- Painting the cutlass! Paint pro's chime in!
- Rallye 350 Bumpers
- Color match
- Dash pads repaint
- Phoenix, AZ Paint Shops
- Opinions on DR Color Chip touch-up paint?
- 1965 cutlass dash paint
- Paint for Carb Linkage etc.
- '73 interior primer
- 70 442 Wheel Paint
- Favorite color scheme
- Air Cleaner Color for 1969 442
- Color research
- 66 Cutlass Midnight Rider
- Clear Coat Options
- 77 Olds Toronado Engine paint
- air cleaner paint
- Blue engine paint
- stainless trim removal
- Prime the bead area on SSIII's?
- Hood Hinges
- "Plasti-Dip" the roof on my Two-Tone Cutlass
- Kicker panel color. Any ideas?
- Inner Fender Resto
- 68 442...Bad Stripes
- Dupli-Color MOTIP Gold Wheel Paint ????
- Paint for a 1970 Oldsmobile cutlass' grilles
- 70 blue interior colors
- Restoration Paints
- 68 fender stripe
- Color Combo Options 69 442
- Never seen this color combo.
- 1981 Color Code 69 Dark Sandstone Metallic
- fender stripes
- 71 cutlass conv
- engine paint
- Paint time, where do I get it done
- Correct supreme grill color
- Fish eye! any paint guys?
- Looking for Reputable paint shops in HI or FLA
- painting instructions
- I've seen some bad paint mismatches, but this takes the cake...
- 68-69 455 engine red color name or code
- Pin Stripe Specification for 1970 Cutlass SX Convertible
- Touch up paint won't buff out the same as original
- paint wheel
- W25 hood stripes
- paint code
- setting blocks
- First shot of color
- Upper Dash color
- Best primer/paint for frame
- Powder Coating Engine Block
- Comments on this PAINT COMBINATION
- Core Support Stone Shield Color
- Chrome Plating Kits
- Correct color for transmission crossmember?
- Dash mark for paint code ( - )
- Temporary protection
- 71 72 Saturn Gold Code 53 Issues
- Orange Peel Hell
- Paint shop referrals- Boston suburbs
