stainless trim removal
Old Apr 20, 2014 | 06:39 PM
jdiggitydogg's Avatar
I am starting the process to paint my 66 cutlass holiday coupe. My buddy paints at a local shop said he would start body and paint if I took out glass and all trim. Ive gotten everything except stainless trim along doors fenders quarters and wheel openings any tricks not to damage clips as well as trim I have noticed its hard to find and expensive and mine is really nice. He probably knows how or someone who does but he is doing me a great favor like to have it ready for him thanks
Old Apr 20, 2014 | 07:20 PM
If you do end up breaking some molding clips, I'm sure you'll be able to find them at places like AMK
If the clips are metal, they likely will be ok but most of the trim ones were plastic. That means they'll be brittle and likely break after almost 50 years on the car.
There is a stainless trim removal tool - don't know if you have one but they're really inexpensive.
Looks like the tool second from the left. Available at most auto parts stores.
Old Apr 21, 2014 | 05:47 AM
mrolds69's Avatar
I know Allan knows this, but it's not 2nd from left. L to R 1 Door Panel 2 Inside window crank 3 Window stainless reveals 4 ???
Old Apr 21, 2014 | 06:58 AM
Can't believe I typed that, I did mean the one you tagged as #3. Thanks for correcting. I think that #4 tool is for removing wipers.
Old Apr 21, 2014 | 09:13 AM
66400's Avatar
Most of your side trim removal will be self evident once you remove the inside interior door and quarter panels. Horizontal moldings will have nuts to remove inside the door and philips screws at the very ends of the door molding. Access the rear quarter moldings nuts from inside the trunk. Wheel lip moldings will be attached with philips screws and shares studs with nuts with horizontal moldings.
Henry
Vern's 63 Starfire
Mar 1, 2014 03:40 PM
71 Cutlass
Body work
Jan 1, 2011 05:39 AM
u8meat
Jan 18, 2009 06:50 AM
tarps3
May 27, 2008 02:14 PM
