PDA
View Full Version : Paint
Pages : 1 2 3 [4]
  1. how much paint?
  2. Has anyone used starfire paint (single stage)
  3. Help with name of color
  4. Painting trunk interior on 72
  5. Color conflicted
  6. What mask to wear while sandblasting, painting?
  7. Factory correct air cleaner paint?
  8. 1964 OLDSMOBILE hood and tailgate letters
  9. Trunk Detail
  10. 1964 330 engine color
  11. Engine Paint: Spray vs. Brush
  12. 1965 cutlass air cleaner
  13. Painting Dashboard
  14. Under Hood
  15. New paint
  16. Anyone have a blue 68?
  17. Color Bamboo
  18. Painting engine.. primer?
  19. Radiator Frame color
  20. 66 Target Red
  21. Chipped hood paint on 69 Cutlass S
  22. Fresh paint on the 68!
  23. Aircraft remover
  24. how to seal her up
  25. Vista Cruiser Hood Stripes
  26. Hood Hinge color
  27. 1970 Cutlass convertible side strips
  28. Finding paint for my '66 Toronado dash...
  29. Refinishing my 68 442 engine compartment.
  30. 64 F-85 915 trim code
  31. 70 brake backing plates
  32. Painting Headlight Surrounds & Taillights- 72 Cutlass
  33. Orange peel still evident!!
  34. Clear Coat Color Sanding Problem
  35. Paint color
  36. Correct paint for engine compartmaent, dash, etc. on a 67 442??
  37. opgi, comments??
  38. i NEED IDEAS
  39. Basecoat formula/
  40. buff swirls
  41. Rust Encapsulator ?'s
  42. Painting over fiberglass/gelcoat 101 questions.
  43. Need help with paint code on 1967 Cutlass!
  44. painting in a garage...
  45. 1959 olds 98
  46. '56 paint code
  47. re-painting 455
  48. Cutlass S - emblem paint color and code?
  49. Tell me the good and bad about Maaco paintjobs.
  50. Which paint for Chassis?
  51. 1963 Starfire engine compartment paint
  52. Black or White? W-31
  53. Home Paint Job
  54. '70 Non W-30 side stripes
  55. How to paint
  56. 1968 Cutlass Tail light
  57. What color is this car?
  58. Got fish eye !
  59. Please help console color
  60. nugget gold vs Saturn gold
  61. 1972 cutlass s color choice
  62. Powder Coat
  63. Help with '67 442 paint code
  64. What color is my car?
  65. 442 color
  66. W29 or cutlass s
  67. '68 Fender Stripe question for Joe P
  68. 72 Cutlass Trunk Spatter Paint
  69. w 29 1972
  70. Sanding is not very fun
  71. Painting Stripes
  72. Paint Code for 91 98
  73. Protective paint for Underside
  74. Poll - 1968 Cutlass Wheel Colour
  75. Earn your "Stripes"?
  76. soda blaster
  77. 55 Deluxe wheel covers
  78. acrylic laquer cover up?
  79. repaired quarters!!
  80. Paint Frustration
  81. Paint code 58 burnished gold
  82. 68 W-30 stripe thread
  83. Finding the right blue
  84. Spray booth rental
  85. Paint
  86. What color is this 442? Yes, I already know it's blue.
  87. About to paint a fender and hood on 71 Cutlass ****First Timer****
  88. anyone sprayed Por 15 ?
  89. Firewall color?
  90. 70 cutlass 455 paint for air cleaner
  91. Painting a Ram Air Hood
  92. Fire damage to paint or not to paint
  93. interior color
  94. 68 hurst olds paint details
  95. rims
  96. Stripe painting procedure
  97. engine paint
  98. Primer engine block ?
  99. 1968 cutlass
  100. removing paint that was painted over the original lacquer
  101. anyone have pictures of 1968 cutlass, black?
  102. Paint Code 60-60-31 on 57 Olds 88 4dr Sedan
  103. buffing Lacquer paint
  104. dash paint color
  105. Black paint for Alternator bracket etc.
  106. Paint code for gold stripes
  107. engine color
  108. 71 Interior Color - Pearl
  109. Car Colors
  110. Don't laugh until you try it. trunk splatter
  111. '72 Cutlass Y70 Pics?
  112. What color is this?
  113. 70 442 W30 stripes
  114. Where to buy OEM Paint Colors?
  115. How should it be done?
  116. You know you live in Canada when......
  117. 83/84 H/O, how high does lower body color wrap around wheel??
  118. which primer ??
  119. Crinkle paint
  120. Gm a-body paint info
  121. Painting my 455 (Bunch of Pics)
  122. new paint color chart
  123. 1970 Twilight Blue - 1972 Royal Blue ?
  124. Cheap paint job?? Macco or Earl Scheib??
  125. Interior Chrome trim paint
  126. What color should I paint my 72?
  127. Removing paint overspray from interior
  128. Omni PaK Master Blend blue 455
  129. Old paint as base
  130. Touch up paint - viking blue
  131. Sandalwood interior
  132. Which is the "original" paint codes? confused!
  133. Value
  134. Engine Compartment paint
  135. 1969 455 paint color
  136. Pinchweld molding install question
  137. Paint system recommendation?
  138. 69 442 paint color Sable
  139. Plastics Paint Question
  140. got her painted
  141. need color from paint code
  142. New Paint regs. in PA - Waterbourne?
  143. Windshield Washer Motor ('72 Concealed)
  144. Water based paints by 2012?
  145. chassis paint
  146. 1968 442 "red" paint source?
  147. Contaminated Paint Booth
  148. 1971 Paint Code 67,How "rare" is it?
  149. body and paint estimate
  150. Need Advise..
  151. Question about correct trunk paint for 1967 Cutlass
  152. Omni Paint Line
  153. the 1967 ford fairlane 500 and oldsmobile 442 holiday coupe
  154. Oldsmobile Gold Paint
  155. What color of paint ?
  156. Close by FIRE clear coat question
  157. What were the colors available for a 78 98 regency diesel?
  158. engine paint
  159. Painting a Engine
  160. Rocket Emblem paint color
  161. Need a good spray gun
  162. SSII correct Argent Gray Shade
  163. What color(s) are the outside of the housings?
  164. "Virtual Paint Job" web site ???
  165. Color problem
  166. W30 Stripes
  167. Primer for my 48 Olds
  168. Black Velvet Engine Paint by POR15
  169. Painting the front of the radiator - good or bad idea?
  170. acrylic urathane
  171. 64 paint codes
  172. Body/cowl tag
  173. Body by Fisher Plate
  174. I smell a rat....
  175. Painted My Engine
  176. looking for a decent 2 stage metallic bright red
  177. Decent driver grade paint job in dallas area
  178. T Bell
  179. Floor pans-guage metal
  180. New Tires & Painting Wheels on 72 Cutlass
  181. another paint question?
  182. 62 Starfire
  183. picture on gallery now,factory color?
  184. clear coat or enamel?
  185. what were the 4 special order colors in 1970
  186. Painting 69 442 400 engine: Restoration help
  187. Interior paint
  188. 62 Starfire Almost Ready for Paint
  189. Interior paint recomendations
  190. Body stripe color code
  191. Specific color?
  192. Interior paints
  193. brush it?
  194. air cleaner info
  195. Paint color for SSII wheels
  196. Painted today
  197. Wet Sanding Tips
  198. What type of paint is used on license plates.
  199. Chipped paint remedy?
  200. Vaper spray guns?
  201. Tips for painting an engine?
  202. inner fender red
  203. Paint for frame/motor
  204. 1985 Paint Code
  205. Eastwood High Heat Exhaust Manifold Paint
  206. Front grill repaint 71 cutlass
  207. rallye 350 paint
  208. door jamb paint removal
  209. painted bumpers to match body
  210. Interior Paint
  211. $30,000 paint job
  212. what color should i paint my block?
  213. 66 SSI wheel color
  214. overspray questions
  215. Rust Bullet RBA52 Paint Rust & Corrosion Inhibitor
  216. Cowl Tag on a 1961 Olds
  217. paint code ?????????
  218. '49 Olds "Green Project"
  219. Paint Oppinions
  220. Finally got some paint on it.
  221. Lead paint concerns?
  222. single stage paint
  223. 71 cutlass paint job
  224. thoughts on paint systems...
  225. what primer in the floor pans ?
  226. new paint problems
