'70 Non W-30 side stripes
Old February 24th, 2011, 01:01 PM
Jacoz70442's Avatar
I've seen quite a few '70 convertibles, but I see some with no side pinstripes, some w/a small single stripe, and some with a small double stripe. What is correct? I have a small black stripe aroun the lower edges flowing over the wheel wells and on the trunk deck following the edge under the lock mechanism.
Jacoz70442 is offline
Old February 24th, 2011, 02:42 PM
stevengerard's Avatar
70 442s should have a thin double paint stripe going the length of the car (one thicker than the other)- .06. top stripe .240 space .200 bottom stripe bigger gap over wheel arches .50 I think. Its in the assembly manual
stevengerard is offline
Old February 24th, 2011, 02:44 PM
Jacoz70442's Avatar
Ok, thanks! This one is incorrect then.
http://www.presidentialautoleasing.c...d-6115683.html
Old February 24th, 2011, 03:10 PM
yes, though you could ask for stripe delete but then there wouldn't be stripes on the hood most likely. I see a lot of 442s without the side stripes, maybe because they are not easy to reproduce or people are just lazy or understandably save money as I'm sure they are not cheap to add as there is no template for them.
Old February 25th, 2011, 10:34 AM
442Harv's Avatar
Even the small thin stripe, would make that yellow car look even better.Have a guy I know, with a 71 convert, green with thin white stripe, looks good.
442Harv is offline
Old February 25th, 2011, 01:40 PM
body 51's Avatar
very nice to see another sebring yellow 442. in fact the car posted has a vin somewhat close to my car and built at the same plant.
my build sheet only shows "special paint change" so i don't know if my car had the stripes or not
the stripes on my car were done a little too wide and therefore not an accurate representation of a 70 442 paint job
body 51 is offline
Old February 25th, 2011, 01:55 PM
Jacoz70442's Avatar
Wow, very nice! I know this color is very few and far between. I see you have SSI's on yours. Have you seen the '83 Car Exchange magazine with the Sebring Yellow '70 on the cover(shot in the dark here as it't pretty old)? That's the only other picture I've seen of a '70 SY 442 non-W-30 until today. How long have you owned yours? Anything interesting you have found about this color on the 442's would be greatly appreciated.
Old February 25th, 2011, 02:08 PM
body 51's Avatar
owned since 1983. car was bought by a friend of mine in '82 on a Cadillac/Chevy used car lot.
The olds chassis manual lists sebring yellow as one of the 3 or 4 special order colors for just about any olds for 1970.
I believe it is the same color formula that chevy used in 1969 and called it daytona yellow
body 51 is offline
Old February 25th, 2011, 04:44 PM
1971 442 conv
Texas442's Avatar
Here are the correct non-W30 stripes on a 70:
Texas442 is offline
e.cast728
April 7th, 2014 04:14 AM
matviar
August 20th, 2012 08:03 AM
tcarroll
Body work
April 4th, 2012 11:54 PM
oldspackrat
December 5th, 2011 05:58 PM
Rohebo
September 3rd, 2009 09:29 AM
Quick Reply: '70 Non W-30 side stripes
