buffing Lacquer paint
Old Jun 23, 2010 | 12:57 PM
scott strange's Avatar
How do you buff lacquer paint? I have wet sanded base coat clear coat before and buffed it out,but is lacquer any different? What should I watch out for? Thanks for any tips someone might have.
Old Jun 23, 2010 | 01:07 PM
Oldsmaniac's Avatar
I have buffed lacquer. Wet sand first then its pretty straight forward. The paint supply store will recommend a grit/polish. Keep the buffer moving and stay away from the tall edges so ya dont buff thru the paint.
Old Jun 23, 2010 | 06:23 PM
Run to Rund's Avatar
3M 05954 compound
Old Sep 6, 2010 | 09:00 PM
67442nut's Avatar
Lacquer isn't as hard or durable as the basecoat/clearcoat paints, so you have to be alot more careful.
Much easier to burn through especially on the edges.
From my experience, the longer you can let lacquer cure before buffing the better.
Old Sep 8, 2010 | 05:24 PM
gbodyfan's Avatar
are you buffing fresh paint or old paint. if its old i wouldnt waste your time when laquer gets old it cracks and that wont buff out. i was board one day and tried to buff stock paint on my g body and there wasnt any difference when i was done
Old Oct 20, 2010 | 07:23 PM
italian ice's Avatar
I don't know my a$$ from a hole in the ground but I can tell you my recent experience. My 68 original paint F85 looked horrible and a highly respected restoration shop owner suggested the best solution was strip to metal and repaint base/clearcoat. That's not what I wanted. My paint had lots of alligator-like surfaces on the hood, doors and quarters.
Feeling like I had nothing to lose, I started on the hood and was amazed at the result after the wet sanding and compounding. I wet sanded with 1500 grit and followed with Meguiars Ultimate compound on my Meguiars Porter Cable Random Orbital sander. 25 hours later, it is nearly done. The worst surfaces got a treatment of 320 grit sand paper, then the wet sanding, followed by a conventional buff with a two speed buffer (at low speed). I can't describe what a difference it made. Here are some pics.
Old Oct 20, 2010 | 07:37 PM
A few more. Note the surface of the door before. I just don't have a good clear pic of the driver side after to compare.
Old Oct 20, 2010 | 07:57 PM
Nice.
You're lucky - your paint was basically sound underneath.
Some paint is cracked deep down and can't be saved that way.
I've had both experiences - I've buffed old paint out to like-new, and I've also wasted several hours on a '68 F*rd, with the finish, as has been noted, no different than before.
If you are buffing new paint, though, then remember that time is on your side.
You will get lousy results if you buff a day or two after painting.
Better a week after, but still not great.
Good if you can wait a month.
A few months would be excellent.
As others have said, watch for edges, be gentle, keep moving, don't go too fast, and don't burn or melt it.
Bfg
Paint
Feb 5, 2013 04:53 PM
65Delta
Apr 22, 2011 02:47 AM
jensenracing77
Paint
Jul 13, 2010 06:58 PM
nelsontj
Care and Appearance
Oct 14, 2009 03:09 PM
scrappie
Apr 30, 2007 04:02 PM
