Care and Appearance Washing, waxing, paint care products, etc.
Temperature Requirements for Buffing/Polishing
Old October 14th, 2009, 01:52 PM
nelsontj's Avatar
Is the outdoor temperature a big factor for a good buffing/polishing finish? The temperature around here will be < 50 degrees F over the next few weeks. I plan on doing a buffing/polishing job to get out some superficial scratches. Do I need a warmer outside temperature to do the job right?
nelsontj is offline
Old October 14th, 2009, 03:09 PM
bcracing's Avatar
That temp shouldn't be a problem, biggest concern is the metal tempature not the air tempature, you con't want the metal tempature freezing, and you don't want it so hot (in direct hot sunlight)that the compound dries on it. Buffing and polishing is basically the same guidelines as waxing.
bcracing is offline
70cutt
Paint
November 11th, 2011 06:43 PM
CutlassLegend
August 6th, 2011 02:53 PM
scott strange
Paint
October 20th, 2010 07:57 PM
68Tom
July 24th, 2009 07:50 AM
scrappie
April 30th, 2007 04:02 PM
Quick Reply: Temperature Requirements for Buffing/Polishing
