Care and Appearance Washing, waxing, paint care products, etc.
Temperature Requirements for Buffing/Polishing
Old Oct 14, 2009 | 01:52 PM
nelsontj's Avatar
Is the outdoor temperature a big factor for a good buffing/polishing finish? The temperature around here will be < 50 degrees F over the next few weeks. I plan on doing a buffing/polishing job to get out some superficial scratches. Do I need a warmer outside temperature to do the job right?
Old Oct 14, 2009 | 03:09 PM
bcracing's Avatar
That temp shouldn't be a problem, biggest concern is the metal tempature not the air tempature, you con't want the metal tempature freezing, and you don't want it so hot (in direct hot sunlight)that the compound dries on it. Buffing and polishing is basically the same guidelines as waxing.
70cutt
Paint
Nov 11, 2011 06:43 PM
CutlassLegend
Aug 6, 2011 02:53 PM
scott strange
Paint
Oct 20, 2010 07:57 PM
68Tom
Jul 24, 2009 07:50 AM
scrappie
Apr 30, 2007 04:02 PM
