removing paint that was painted over the original lacquer
Old Jul 13, 2010 | 05:19 PM
jensenracing77's Avatar
our 72 cutlass has the original paint, all but the passenger front finder and looks like they tried to blend it into the door. it don't match at all well. i had some masking tape on the finder and when i pulled it off the paint came up with it and left the original pant under it. how do i take all the paint off without hurting the lacquer under it. if it is possible i would like to strip it and find out why they repainted it and then have someone paint it to match better. i may be dreaming here but thought i would ask.
Old Jul 13, 2010 | 05:43 PM
ijasond's Avatar
Purveyor of Polyurethane
If it's been painted over, there's no saving it. You'll bee looking at just getting it repainted.
Old Jul 13, 2010 | 05:48 PM
sx455raidercelticfan's Avatar
i paint 4 a living and i dont think theres any way 2 remove just the color matched area you might get lucky and get some more off with tape but you might take it 2 medal and cause more damage, if you plan on painting later on make sure you strip all the color match area if its coming off with tape it will chip if you paint on top of it!!
Old Jul 13, 2010 | 05:53 PM
oyea if there was major damage 2 the door youll be able 2 see the damge if you take the door panel off and look from the inside, keep your fingers crossed that it was a good body man that did the work!!! i hate it when people drill holes in the body 2 pull the dent out!!!! if you dont see much damage from the inside then your good it was minor, if its all dented in, warped with wrinkles, or has alot of holes with bondo worms coming threw than it was a big hit and alot of work done
Old Jul 13, 2010 | 06:58 PM
i had the door panel off and there are no signs of any damage to the door. i think they was just trying to blend it. the paint feathers to the original paint about half way through the door. i can't see any damage from the back side of the finder but i can't see all of it while on the car. i would bet that it was a good scrape and nothing major. there are no signs of anything else being replaced or bent.
CLcutlass
Paint
28
Feb 6, 2020 05:57 PM
huskalade
Jun 12, 2014 01:01 PM
Bfg
Paint
Feb 5, 2013 04:53 PM
65Delta
Apr 22, 2011 02:47 AM
scott strange
Paint
Oct 20, 2010 07:57 PM
