dash paint color
dash paint color
I am restoring a 1969 442, trim code 934, steering column color D-U and build sheet box 44 color 75 50 50N6. I would like to identify the name and possibly a supplier of the gold paint on the dash under the windshield? Thanks to all of you olds restorers for your help on this great site!!!
You can go to TCP Global's color library and see the original color chip sheets.
http://www.tcpglobal.com/autocolorlibrary/
Car Paint Online ,TCP and others will mix up the paint and ship it to you, in liquid or put into spray cans, or a local car paint place can mix it up and usually can do the cans too if you don't have spray equipment.
http://www.carpaintonline.com/index.php
According to the sheet the only gold is Dark Gold for the top of the instrument panel and that's what code 934 specifies for the dash top, should be flat paint.
934 is Medium Gold semi-gloss for the rest of the interior.
75 is Aztec Gold Poly.
50 is Cameo white
Steering column deal is new to me?
50 is Cameo white
RAMBOW
Dec 7, 2017 07:22 PM
