Need help with paint code on 1967 Cutlass!
Old Mar 23, 2011 | 05:12 PM
paulo's Avatar
Hello all Oldsmobile enthusiasts.I am in need of help.A friend here in Rio de Janeiro just bought a ´67 Cutlass in excellent shape with only 2 previous owners.Its gold with blak interior,330,automatic,console,buckets,2 door no AC.We need to find out the correct paint formula and the mixers down here have no clue.Can someone help? This is the tag:
12C 67.33817FRA3546 Body 970-B E2X GR 4F 5P
Maybe an export model or a domestic car brought over back then.
Paulo
Old Mar 24, 2011 | 08:34 PM
2blu442's Avatar
Welcome to the site! I'm sorry, I don't have the answer to your question but this will move your post back to the top. Hopefully someone else has the information you need. John
Old Mar 24, 2011 | 09:24 PM
2blu442's Avatar
Paulo, I had forgotten about a site that is specifically for the 1967 Cutlass/442. Check it out and if you don't find the answer there please post here again. John
http://www.oldsmobility.com/
Maybe this page: http://www.oldsmobility.com/old/cowltag.htm
Old Mar 25, 2011 | 04:58 AM
paulo's Avatar
John
Thanks for writting.Amazingly the B letter on my tag is not listed as a collor! But I imagine its either the Gold or the Champagne.But it was indeed the oem paint.I will keep on researching.
Paulo
Old Mar 26, 2011 | 07:07 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO Paulo and good luck with the paint color.
Old Mar 26, 2011 | 07:43 AM
2blu442's Avatar
Paulo, could you post a picture of the trim tag? Maybe someone will find a clue that will help identify the factory color. I know you posted the codes, but the location on the tag may help key things out. John
Old Mar 29, 2011 | 04:40 PM
paulo's Avatar
paint blues
John and Oldsmopeople
I took a good look at the tag and its indeed a code G-G meaning gold color.I called PPG Brasil and to my amazement they can not locate the formula!!!! They say it does not exist... The information I have is 22818 gold poly.The paint shop wants to kick the car out! Its in primer.I begged for a few more days.Please help with the formula!!!!!!!!!!
Paulo
Old Mar 29, 2011 | 07:27 PM
2blu442's Avatar
Paulo, I changed the title of your thread and moved it to the paint section. Hopefully someone who really knows paint codes or a 1967 guru will see your post and be able to help! John
Old Mar 30, 2011 | 03:17 AM
Bluevista's Avatar
Registered
22818 is the PPG code for the paint?
The GM code is WA3667.
Carpaintonline has it if you want to order it.
This has the PPG/Ditzler, Dupont and Sherwin Willams codes for Gold Mist Metallic.
http://paintref.com/cgi-bin/colorcod...model=Chevelle
My paint guy uses Spies Hecker and he had them color match it using their color matching device on the original door jambs before they were prepped and they mixed it up. The paint rep dude was very proud of it.
The color and metallic is almost exactly the same as original, I have a factory color plate compliments of a member here.
Old Mar 30, 2011 | 08:50 AM
Run to Rund's Avatar
12C = built December 1966, third week
33817 = Cutlass hardtop model
FRA = built at Framingham, Massachusetts plant
970-B = interior color and type
E = tinted glass (all; option A01)
2 = group 2 options; X = floor mounted automatic transmission shifter
G = console (D55); R = rear shelf speaker (option U80)
4F = group 4, F = remote mirror (?)
5P (?)
my list had the F in Group 5, which could be an error; I don't have P on my list. This list did not come directly from Olds so may or may not be completely accurate.
Old Mar 30, 2011 | 09:59 AM
arodenhiser's Avatar
STOP call'n it a Chevelle
Paulo
I not a guru on '67's or paint. I have a scan of the '67 PPG card.
This agress with you. According to this site....
http://corvetteattitude.com/cgi-bin/...page=4&rows=50
.... G - 1967 Oldsmobile Gold Poly is :
GM code WA3667
PPG code 22818
Dupont code 4825L or 4825D
ShermanWilliams code 910
Maybe one of these code you supplier can source.
Does your car's paint seem similar to this....
Adam
Old Mar 30, 2011 | 11:32 AM
Go to www.autocolorlibrary.com and enter the GM paint code 22818,(for 1967 Oldsmobile) and it will give you the info that you need.
pfergy600
Paint
41
Jun 10, 2015 02:56 PM
racing8up
Paint
Jan 20, 2010 03:53 PM
made in the usa
Dec 6, 2009 09:10 AM
nick77
Oct 10, 2009 08:37 AM
My442
Jul 28, 2009 11:58 AM
