Primer for my 48 Olds
Old Sep 21, 2009 | 04:12 PM
citcapp's Avatar
Ok all you paint guys time to help out. I am disassembling my 48 in preperation of finishing the body work. It has some flash rust so I will be media blasting to get rid of it. So when it is nice and clean what primer do I use to protect body parts while I am doing the prep work to keep the rust away and also help find all of those little inperfections that I will be filling and working with unitil I can send it to the paint shop.
Thanks in advance.
Pat
Old Sep 21, 2009 | 04:37 PM
Gary's 2 442-S's Avatar
Gary
I used PPG (40LF). I have had it on over a year now since I took the body down to bare metal. I see no signs of rust. I would think that any good epoxy primer would work.
Old Sep 21, 2009 | 04:40 PM
bjtstarfire's Avatar
Direct metal epoxy primer.
Old Sep 22, 2009 | 08:06 AM
citcapp's Avatar
Thanks for the replys. ratio of primer to thinner?
Old Sep 22, 2009 | 08:46 AM
Bluevista's Avatar
Registered
I used Kirker 2K Enduro-Prime epoxy primer and it's mixing ratio is 1:1 with the catalyst and can be reduced if you want to use it for the sealer.
Mine has been on the car three years and not a sign of anything either, not that any rust should be covered, moisture can't get through it and start rusting the steel like the old lacquer primers I guess.
Old Sep 22, 2009 | 09:03 AM
Gary
the PPG is 2:1 I used DP401lf for the (catalyst). If you like maybe you can try the expoxy primer from TCP Global http://www.tcpglobal.com/restoration...oprime.aspx,it will save you money but the problem I had with it was it was not mixed very well when I received it. I had a hard time getting it stirred up but it did work.
Old Sep 22, 2009 | 04:12 PM
the paint shop should give you a spec sheet on the ratios for the product you buy.
pinky
Paint
Mar 16, 2009 07:03 PM
68Tom
Jan 25, 2009 05:30 PM
scudinferno
Oct 14, 2007 02:51 PM
Want-A-Vert
Feb 14, 2007 11:51 AM
American Lead
Dec 18, 2006 05:32 PM
