Paint
x2
Is the base messed up or did you lose the recoat window for the clear?
The best bet is to look at your basecoat tech sheet and see what they say to do after you lose the window, that would be where sanding or scuffing and whatever else you have to do would be mentioned.
Normally if you sand base you have to basecoat again before clear, the clear needs a chemical bond to the base or it can delaminate.
jensenracing77
Paint
Sep 10, 2014 02:33 PM
JpMotorsports
May 15, 2014 07:08 AM
