Paint
Old Sep 16, 2010 | 07:55 PM
Gary's 2 442-S's Avatar
Gary
Paint
Has anyone sanded base before putting on the clear coat?
Old Sep 16, 2010 | 08:09 PM
MN71W30's Avatar
Yes I have, But it was a solid color and it was needed to repair a mistake. After another coat, the car was cleared. I've heard of sanding in between clear coats but not the basecoat paint.
Old Sep 17, 2010 | 01:19 AM
Bluevista's Avatar
Registered
x2
Is the base messed up or did you lose the recoat window for the clear?
The best bet is to look at your basecoat tech sheet and see what they say to do after you lose the window, that would be where sanding or scuffing and whatever else you have to do would be mentioned.
Normally if you sand base you have to basecoat again before clear, the clear needs a chemical bond to the base or it can delaminate.
Jamesbo
Paint
Jun 13, 2020 09:02 PM
jensenracing77
Paint
Sep 10, 2014 02:33 PM
JpMotorsports
May 15, 2014 07:08 AM
dlmsavings1
Sep 3, 2013 09:01 AM
442mom
Nov 22, 2002 08:12 PM
