To Etch or not to Etch
Old May 12, 2012 | 03:15 PM
Troys Toy 70's Avatar
Once Olds Always Olds
I’m in the middle of wire brushing the front of my frame (see pics) I have both epoxy primer & paint and por 15. I do not have the por metal prep. This is not a frame-off, just a front-end rebuilt that has MAW’d . My question is twofold+. Can I por 15 over this, no etching or other metal prep, (Could sandblast; but that leads to the next question), OR if I epoxy prime and paint, what is the easiest way to keep the overspray down? Hood is off, fenders still on, a lot of area to try to mask off just to paint the frame. She is a driver, not a trailer queen.
Old May 12, 2012 | 04:15 PM
501Paratrooper's Avatar
I've used por15 quite a bit and been happy with the results, If you go with the por15 still sandblast and use the metal prep 1st before applying.
Old May 12, 2012 | 05:19 PM
I'd use one form of MetalPrep or another.
Essentially the same thing (phosphoric acid compounds) is sold by a number of reliable paint companies, as well as by POR. You can also get the same thing at hardware stores and Home Depot.
I would not pay POR's price for something I could get MUCH cheaper at the Despot.
Old May 12, 2012 | 07:15 PM
Lady72nRob71's Avatar
Wow - a familiar sight!
YES - Use the metal prep or prep and ready. Despite my initial thoughts of it, this stuff really works.
POR15 and other paints fisheye and/or run when used on smooth surfaces. The prep chemicals etches the smooth metal into a chalkboard-like roughness, so paint really sticks! Rinse off after 20 minutes and dont let it dry.
See my underhood resto thread to how the prep etches and how nicely the paint adhered after being brushed on with cheap chip brushes. The few tiny areas I missed with the etchant, the paint kept creeping from.
Wirebrushing does not create the tiny pits that sandblasting does, so etching is important. Only if it was well sandblasted would I say skip the etch.
Old May 12, 2012 | 07:16 PM
Boldsmobile's Avatar
What does Home Depot sell that is like POR 15?
Old May 12, 2012 | 08:00 PM
I'm afraid I wasn't clear.
Home Depot sells a phosphoric acid metal prep solution like the one that POR sells for $$$$.
They do not sell the paint that POR sells.
Sorry.
Old May 12, 2012 | 08:12 PM
Did you lightly sandblast, or go over it a couple of times to really etch it. What I have been sandblasting with is just a nozzle and some play sand.
Also didn't you just redo your grills a while back, what color of silver did you use?
Old May 12, 2012 | 08:15 PM
Lowes is closer to me. They have a product called Jasco Indoor outdoor paint prep. Can tell what all is in it. Does it sound familiar?
Old May 12, 2012 | 08:36 PM
The stuff I got at Home Depot (about 2 years ago) is Klean-Strip Phosphoric Plus. Checking the web, I see that that company now sells Phosphoric Prep & Etch, which I would wager is the same thing with a different name.
Lowes usually has all of the same stuff as Home Depot, just from different companies.
Old May 12, 2012 | 08:40 PM
Yep, still plugging along..I have a couple of boxes of rotors and brakes pads, another box coming from ILT that should arive Monday with new bolts and a few odds and ends. Get this frame painted........ and should be able to start puting it back together. Yea....I drew the line at the firewall for the MAWs.... I'll work on it this winter. Otherwise, I won't drive it this summer and that is unacceptbale.
Old May 13, 2012 | 06:09 AM
I hope you mean stop AFTER doing the firewall... It was pretty easy to access for clean and paint after all the other stuff was removed. Did not add but a couple more days to the project.
Old May 13, 2012 | 06:23 AM
No, I meant before the firewall, and here is where the MAW's run amok. I have new (still in box) aftermarket fenders that the guy gave me, when I bought the car. They will need painted, then the radiator support will need pulled, sandblasted repainted, bumper recromed, new brake lines, new booster. All that not in budget right now.
Tom442
Mar 20, 2022 06:20 PM
CLcutlass
Paint
28
Feb 6, 2020 05:57 PM
jensenracing77
May 29, 2015 01:20 PM
coppercutlass
Mar 2, 2015 02:49 AM
