Metal Flake Paint
Old Nov 25, 2012 | 01:37 PM
Delmont 88 PA's Avatar
Metal Flake Paint
Have any of you painted metal flake in the not too distant past? I'm going to paint my Delmont (custom with shaved door handles and a cowl induction hood) with metal flake but have no experience with anything but enamels and urethanes (base coat clear coat). If possible I want to keep the bright red as the base.
Thanks,
Chris
Old Nov 26, 2012 | 08:34 AM
m371961's Avatar
You may want to check for the answer at autobody101.com
Great site for a question like this
Old Nov 26, 2012 | 05:14 PM
Thanks!
Old Dec 1, 2012 | 03:31 PM
Santa is bringing a Flake Buster so I'm now committed to full metal flake. From what I read you lay down your base coat, spray on an intermediate coat of clear (thicker clear to suspend the flakes better), knock down the flakes and then clear it.
Old Dec 14, 2012 | 12:59 PM
jfb's Avatar
jfb
if it mottles use a dust coat to calm it down and do not do the trunk or hood side to side it will probably tiger stripe go the entire width top to bottom medium wet.
Old Dec 14, 2012 | 03:18 PM
ihengineer76's Avatar
There are a couple things to do to get metal flake and metallic to lay nice. The first is set the fan of your gun quite wide. When you are spraying, don't go in any particular pattern, but rather spray kind of erratically around while making sure you get good coverage. This is going to cause more overspray and use more paint, so be prepared for that. When doing multiple coats, don't leave as much time in between coats, and I usually step down to a lower temp reducer to give the paint more time to level and the coats to blend. On the last coat of the metal, lightly fog it all over to get a good finish dusting.
Old Dec 15, 2012 | 07:29 PM
ent72olds's Avatar
Registered Luser
Some good advice, but I think you meant to say,"high temp reducer"......
Old Dec 16, 2012 | 07:33 PM
Whoops, mental slip haha. Yeah I meant to say High Temp.
Old Dec 16, 2012 | 07:57 PM
47 Convertible's Avatar
metal flake
Maybe wise to get some sheet metal pieces like an old hood or trunk lid and practice before hand to get the feel of it.
Old Dec 18, 2012 | 04:33 PM
Thanks for the replies and I will practice. We have an old set of rally wheels that will be some metal flake color before the end of winter!
Olds luvr
Feb 22, 2022 10:24 PM
hilbily
Body work
Sep 9, 2014 08:54 PM
KZ442
Aug 12, 2010 08:14 PM
Kidcutty
Jan 18, 2010 04:04 PM
Keieljun
Apr 28, 2008 03:25 AM
