DuPont 69 H/O Firefrost Gold base/clear no more.
Old Jun 19, 2012 | 05:03 PM
69HO43's Avatar
I just learned from Kurt Karch, 69 H/O advisor for the Hurst/Olds Club of America, that the current DuPont 69 H/O Firefrost Gold formula base/clear formulation is no longer made. Two of the ingredients, transox yellow and moss green pearl, are dropped from their materials list.
Just passing this along.
PPG 5090 may still be able to be made, which looks pretty close.
Old Jun 19, 2012 | 05:24 PM
Gator69olds's Avatar
So what's a guy suppose to do if he nedds to paint his '69 H/O again?
Old Jun 19, 2012 | 06:09 PM
coppercutlass's Avatar
Chevy budget Olds powered
They usually give you formulas to make tints to those specs. They usually used a diffrent product. Same w/ppg. If you call their color library they will set you up w/ what you need. I went through the same thing when I got my paint. I had to make like 5 diffrent calls to get the correct color in an updated formula.
Old Jun 19, 2012 | 06:18 PM
Frank3's Avatar
Dupont stopped making lacquer , and when the did they tossed all the mix formulas for the older cars . No cross over to anything they offer . I was told to match it to something in their color chart , or look else where , by Dupont .
Old Jun 19, 2012 | 06:22 PM
I know with ppg they gave me the code to the updated formula. I actually think I have the sheets they sent my shop I'll have to dig in my tool box and see.
Old Oct 8, 2013 | 11:38 AM
pogo69's Avatar
morgan
just talked to the local paint shop and they have plenty of moss green and trans ox.yellow...said only the 1008s moss green is dis-continued not the 890j trans.ox yellow??... i was hoping to find formulas in orig lacquer and 1 stage enamel
Old Oct 8, 2013 | 12:13 PM
mmurphy77's Avatar
We had paint mixed to match the Gold in the "H/O 455" hood scoop decal and it looks perfect!
Old Oct 8, 2013 | 05:23 PM
ent72olds's Avatar
Registered Luser
Not true....who told you this?
Old Oct 8, 2013 | 05:25 PM
ent72olds's Avatar
Registered Luser
The reason these products were dropped was due to EPA regulations on HAPS....the formula will exist, but with a replacement toner....
Old Oct 8, 2013 | 05:47 PM
allyolds68's Avatar
You're lucky you had a formula that worked. Most colors don't match worth a damn anyway. If you try to paint a 68 using the "original" PPG Scarlet formula you get something that looks closer to Mary Kay pink than red. I had the painter get a scan of the underside of the trunk and then tweaked it until it was correct. He painted half the underside of my trunk lid four times until both sides matched.
Old Mar 6, 2016 | 07:24 AM
HairyHurst's Avatar
Hi all. Getting ready to do repaint of Demmer # 204. I see that the (standard) firefrost gold recipe has agents in it that are no longer available. Has a new standard been determined ? Sure would like to know if its out there. This is the last time I will be painting this car. Thanks
Old Mar 6, 2016 | 12:02 PM
69HO43's Avatar
If you can't get the DuPont formula ingredients, then you may have some success with a paint shop that uses PPG products. Check PPG 5090. Can't recall who's car it was, but they got theirs repainted with #5090 and when I matched my DuPont test color square up to it, it was extremely close match.
The gold on the hood scoop decals was completely different than the body paint gold. Do not use that as a guide for the body gold. The decals were screen printed and had a paper-like base to them according to a decal company I had investigate an original number I had carefully peeled off the scoop. They said they hadn't done decals like that in YEARS and it would be incredibly expensive to reproduce as the methods/materials were leap-years ahead of the dinosaur decals.
They manufactured the original gold formula in lacquer under 5196LO. I talked to a zillion people at DuPont when I was doing research on this and ended up talking to an old guy in DuPont's paint archive department and the original formula card pulls up, but guess what? The ingredient list is blank. No other information. He said EPA was responsible for that.
(If you need the Cameo white, it is DuPont code 5033L [WA3967]). If you go with PPG stuff the white is listed under #2058.
Old Mar 8, 2016 | 07:49 AM
HairyHurst's Avatar
Thanks for the quick reply 69HO43. I guess by your opening comment I may get lucky and find the missing agents in the Dupont formula by looking around. Thanks again.
Old Mar 8, 2016 | 09:28 AM
pogo69's Avatar
morgan
if you need some of the dupont moss green pearl and yellow transoxide powder i have some, if you know the grams of each needed let me know and i can check... these 2 tints are not being made anymore but are still available
Old Mar 8, 2016 | 10:19 AM
69HO43's Avatar
This is what I got from the DuPont/Demmer tag team when DuPont resurrected the paint in a base/clear ChromaPremier about 18 years ago. It's for a pint.
The formula given is for one pint (DuPont says it’s enough to do one car’s stripes when thinned, but I’d personally go with a quart) of the more expensive ChromaPremier. I recommend test spraying the mix first to make sure that it’s what you want. Take this to your DuPont jobber. It MAY be under the name of "69 Hurst/Olds Gold". It wasn’t in the computer systems last I checked. If you need a quart, double the amounts shown.
Cost code from DuPont: (important) F
4530S Flop Control Agent 45.4
890J Transox Yellow 86.0
894J Extra Coarse Alum 109.3
845J Transp Yellow 131.0
895J Bright Coarse Alum 149.9
802J LS White 161.1
832J Green 162.0
1005S Gold Pearl 180.7
1008S Moss Green Pearl 181.0
62320F Binder 326.3
62330F Balancer 457.5
Old Mar 8, 2016 | 05:31 PM
pogo69's Avatar
morgan
890j is 86.0
100s is 186.0 what is the weight (grams ??) of these numbers?
Old Apr 3, 2016 | 05:53 PM
HairyHurst's Avatar
I was able to locate all the components locally and had my paint shop spray a swatch for me,but I am still not sure it's a close m match. I took to the swatch to the Olds museum to match up with the Bagelys 69 Hurst on display it did not match up. The paint on there car was darker,maybe do to original age ?. I was wondering if anyone may have a sample I can compare to. I sure like the firefrost gold that was put on the west coast convertible car. Here is the picture of the swatch.P_20160403_102400.jpg
Old Apr 4, 2016 | 12:22 PM
Eddie Hansen's Avatar
interested...
I will be seeing how this comes out, would be interested to find a formulae with the components available today
Old Apr 4, 2016 | 05:12 PM
timholliday's Avatar
Member
Here is the PPG paint used on my car back in 2007. Have not seen this color mentioned as a viable option. Looked very close compared to other H/O's through the years.
Old Apr 7, 2016 | 06:55 PM
Member
A quick heads up that PPG 5090 is not a viable option. Had a half pint mixed and it is an olive color.
Old Jul 10, 2016 | 07:52 PM
Tim did you use the same paint when you did your convertible?
Old Jul 11, 2016 | 05:26 AM
Member
I used this formula on the convertible. Turned out very nice.
Old Jul 11, 2016 | 09:38 AM
Thank you Sir!
Old Jul 11, 2016 | 11:01 AM
I thought the whole point of this now-resurrected thread is that two of the ingredients on that formula are no longer available. When did you last have it mixed?
Old Jul 11, 2016 | 12:53 PM
Member
I had the paint mixed right around April 15th, 2016
Old Jul 11, 2016 | 12:56 PM
Kewl. Thanks.
sicky olds
Oct 21, 2014 09:44 AM
Del70
Sep 30, 2014 07:21 PM
mmurphy77
Nov 2, 2012 08:36 PM
sx455raidercelticfan
Jul 23, 2010 07:11 PM
